First order circuits, Inductors
1 reply · 4K views
popo902
A security alarm for an office building door is modeled by the circuit [below]. The switch represents the door interlock, and v is the alarm indicator voltage. Find v(t) for t>0 for the circuit [below]. The switch has been closed for a long time at t=0-
http://i36.photobucket.com/albums/e47/jo860/img014.jpg
V = L di/dt
ok so, i see that it has been closed for a long time, which must mean the inductor is "charged" and at steady state at t=0-, t=0+, and i think also t=0 since current cannot change instantaneously
I used mesh analysis and found the current "stored" in the inductor to be 2A
then i see that when the switch is opened, it splits the circuit into two circuits...right?
so then only the left side is where i work.
then the inductor would sort of be like a finite current source pumping current through the 9 then 3 ohm resistor--the opposite way the previous current was going(is this correct?)
I see it like if i find the current through the inductor at t>0, then i just multiply that by 9 to get the voltage across 9
could someone maybe give me a hint to what I'm missing or if I'm wrong?
would it right to use KVL?
V = L di/dt
No, the current through the inductor continues in the same direction.
This is true only at t = 0. After that the current and consequently the voltage through the resistor will diminish.
You can use KVL to write the differential equation for the mesh. After that, you solve the equation with the initial condition i(0) = 2.
