First order nonlinear differential equation Help needed.
The discussion revolves around solving a specific first-order nonlinear differential equation of the form 0 = a*[f(t)]^{z/(z-1)} + (-t+C)*f(t) + b*[df(t)/dt], where a, b, and C are constants and 0 < z < 1. Participants explore various methods and approaches to tackle this equation, including the use of integrating factors and substitutions.
  • Karen presents the nonlinear differential equation and requests assistance in solving it.
  • One participant suggests finding an integrating factor, providing a link to a step-by-step explanation.
  • Karen responds that the integrating factor technique is ineffective because it results in a function of both "t" and "f".
  • Another participant proposes simplifying the problem by working on a related, simpler differential equation and suggests a substitution method involving u=f^{1/2} to convert the equation.
  • Karen acknowledges the suggestion but notes that the negative value of z/(z-1) complicates the solution process.
  • Karen expresses difficulty in applying the proposed approach due to the problematic nature of the negative exponent.
  • A later reply introduces additional substitutions for different forms of the equation, suggesting u=f^{3/2} and u=f^{5/4} for further exploration.
Participants do not reach a consensus on a solution method, and multiple competing approaches are presented. The discussion remains unresolved regarding the best way to tackle the original differential equation.
Participants express concerns about the implications of z/(z-1) being negative, which may affect the validity of certain solution methods. The discussion highlights the complexity of the problem and the challenges in applying standard techniques.
plushval
Hi All,
I have been trying to solve following nonlinear differential equation, but I couldn't solve it.
where a, b and C are constants and 0< z<1.
Could you please help me how to solve this nonlinear differential equation? I would really appreciate any suggestions. Many thanks, in advance!
Karen
Thanks a lot for the suggestion, but unfortunately I could not make integrating factor technique work since integrating factors turns out to be a function of both "t" and "f". Any other suggestions?
Kind regards
I got a suggestion: When you get stuck, fall back and work on a simpler one first, then build it back up to the original problem:
[tex]f'+f^{1/2}+(c-t)f=0[/tex]
now, what happens if I let [itex]u=f^{1/2}[/itex]
you can convert that to a DE in u right?. You know, f=u^2, f'=2uu'. You can do that? Ok, put all that back in, solve it for u, then of course f=u^2. Ok, how about:
[tex]f'+f^{3/4}+(c-t)f=0[/tex]
same dif. Let u=f^{1/4}. Now when you figure out what u is, then raise it to the fourth power to get f.
How about:
[tex]f'+f^{n/m}+(c-t)f=0[/tex]
How about when n/m is not rational?
I will definitely try to solve it in the way that you suggested jackmell. Thanks a lot!
As a quick note, z/(z-1) is negative; hence it may cause some problems.
As I said, z/(z-1) taking negative values is very problematic, therefore unfortunately, I could not solve the ODE using the approach you suggested, jackmall. I appreciate your time, though.
Any other suggestions would be highly appreciated.
Kind regards
If:
[tex]f'+\frac{1}{f^{1/2}}+(c-t)f=0[/tex]
then what happens if we let:
[tex]u=f^{3/2}[/tex]
If:
[tex]f'+\frac{1}{f^{1/4}}+(c-t)f=0[/tex]
[tex]u=f^{5/4}[/tex]
  • · Replies 24 ·
