atlbraves49
- 80
Does anyone even make fixed power supplies of these values? I haven't been able to find any so far.
Phrak said:What's the application? Do you need bench supplies or something to supply power to a product? Should the +/- supplies be dual tracking? Should it take power from the AC lines?
What are your current requirements?
Corneo said:I would just use some bench top power supply. You can get cheap ones from radio shack or expensive ones from Agilent.
Phrak said:I'd use a couple 9 volt batteries. Buy the little snap on leads at radio shack. Apparently, that's why the drawing shows the op amp biased by +/-9V, which is not otherwise a common practice.
Except for the fact that I took a look at the MCP6001 datasheet. It takes a single ended 5.5V maximum supply.
There's something fishy about your drawing. It calls a feedback resistor a 'reference resistor'. This is enough to discard it as completely suspect, if you pulled it off a web page somewhere.
atlbraves49 said:k bench top power supply it is (and batteries won't work, I was told by the flexi force engineer).
I know some of you have seen this, but is this power supply adequate, and are there any less expensive ones available?
http://salestores.com/pr30trouposu2.html
Corneo said:Hmm perhaps another clue? Based on what I've seen in the past, it seems the fan is to control the ambient temperature within the instrument. Which could fluctuate as much as 30 degrees inside as compared to outside the casing.
BTW: Have you checked your inbox?
Proton Soup said:what do you think would be the heaviest thing in the box?
[/URL]atlbraves49 said:They would be used to power this circuit:
http://www.tekscan.com/images/flexi-circuit-new.jpg
berkeman said:Quiz Question -- why would them saying it has a fan make me think this supply would be good for analog work? (Well, that plus the physical size for the powers listed...)
berkeman said:QQ Answer -- And the weight thing. It's a linear power supply, based on its weight for power output, and a linear power supply has no output noise versus a switching PS. Analog circuits do not generally tolerate PS noise all that well.
Phrak said:Fowl, I say! An expert level question. But, perhaps posting a quiz question like this one could be interesting on occasion, whenever you run across one on the job...
mheslep said:And as above I question the given +/-9 supplies in that schematic for the MCP 6001. This data sheet shows VDD-VSS=7v, so +/-9 will blow it for sure, -/+5 may too.
Phrak said:7Volts is the absolute maxium rating.
Inline quiz question.
What is the difference between absolute maxium rating (usually listed at the beginning of a data sheet) and...well, just the plain maxiumum?
For the version we've found online apparently, but perhaps there's an upgraded part suggested by this sensor mfn? Certainly +/-9 is not extreme for CMOS op amps in general.Phrak said:7Volts is the absolute maxium rating.
