DaveC426913
2025 Award
- 24,682
- 9,071
Okay, I've composed a letter to Mythbusters regarding the https://www.physicsforums.com/showthread.php?t=544619" thread.
(I started a separate thread here to avoid any weird recursivity issues in case the Mythbusters ever follow up on my link).Before I submit it, can you guys offer any improvements to my text? (Such as how I can work in a date with nerdy-yet-ultra-hottie Carrie?)
On a physics forum (https://www.physicsforums.com/showthread.php?p=3583247#post3583247) we have been discussing the plausibility of floating an extremely large vessel in an extremely small amount of water. Ideally, an ocean liner in a bucket of water.
It is totally counter-intuitive - how can 40lbs. of water support a 100,000 tonne vessel? The best physicists and engineers on our forum rage against the idea - yet ultimately they come around to the realization that it is perfectly doable - at least in principle.
The idea is that the container holding the water is perfectly form-fitting around the ship's hull, with nary a millimeter of clearance. As the boat is lowered into the container, it will ultimately displace the small amoniut of water, which will rise up the hull until it reaches the waterline of the boat, at which point the boat will stop sinking before touching bottom, i.e. floating.
I won't go into the details of proving it is so, but it is most undeniably so. (You can always follow the thread above to hear all the arguments and counter-arguments.)
I think this needs to be seen to be believed!
In my opinion, the experiment would not be effective unless done at a relatively large scale. It's one thing to float a 10 gallon boat on a cup of water, but that's only a few orders of magnitude between mass doing the displacing and mass of remaining water. I think people would need to see it in terms of several hundred pounds - enough to make a many-orders-of-magnitude discrepancy between the mass of the vessel and the mass of the supporting water.
I envision a plexiglass box nested inside another plexiglass box, with only a millimeter clearance. (It needs to be transparent so you can see the water rising around the inner vessel.) The whole apparatus being at least as big as a refrigerator.
You'd need to demonstrate unequivocally that the bottom of the boat is not simply resting on the bottom of the container. We've thought of some ways to do this.
1] Electrodes. if the inner and outer vessels touch, an alarm goes off. Very tricky and error-prone.
2] Coloured water. If the water were deeply dyed with ink, you could see up through the bottom of the outer vessel and see that there is a thin coloured film of water all across the bottom. If it were touching, you'd see no inky colouring and could see right through to the inner vessel.
What think?
