Flow of Water in a plastic bottle
The flow of water from a plastic bottle occurs when the lid is removed due to the pressure difference between the inside and outside of the bottle. When the lid is on, the air pressure inside the bottle equals the external pressure, preventing water from flowing out. Once the lid is off, the air pressure inside decreases as water exits, allowing the external pressure to push the water out. When the lid is replaced, a vacuum forms, reducing internal pressure further and stopping the flow. Thus, the flow of water is directly linked to the pressure dynamics created by the lid's position.
xorisa
You open the plastic bottle lid to take a drink,and notice fluid flowing from a small hole in the bottom of the bottle. You put the lid back on and the flow stops.
Explain why the flow did not start until the lid was off.
Explain why the flow stopped when the lid was put back on.
None
I thought that this has something to do with the pressure and the continuity of flow because liquids are non compressible but it's still not making sense to me. Could this be something about the Bernoulli effect?
What will happen to the air above water (volume and pressure) if some water will come off the small hole ?
So is it that because when the lid is closed there are no air pressure acting on the water and also air pressure from outside is acting on the small hole so that keeps the water in?
No. If some water goes out when the lid is on, a slight vacuum starts to develop in the head space.
Can you elaborate on that? My understanding is that because the lid is on, the air pressure on the outside is equal to the air pressure inside, and because the air pressure is pushing on the bottle on all sides, thus the water stays in the bottle.
The air pressure on the inside is less than the air pressure on the outside. This is because when some water leaves the volume of the air inside increases. So it's pressure drops.
Mostly it happens due to the pressure difference between outside and inside. The pressure inside the bottle is less than the atmospheric pressure; hence there is no force to push the water from inside.
Isn't that what I said in post #6?
