Fluid Dynamics-D'Alembert's paradox
  • Thread starter Thread starter hhhmortal
    Fluid Paradox
D'Alembert's paradox highlights the counterintuitive result of zero drag in nonviscous, irrotational flow around a cylinder. The discussion focuses on deriving Equation (2.38) from Equations (2.36) and (2.37), emphasizing the significance of the tangential velocity component while noting that the radial velocity is zero at the cylinder's surface. The paradox arises from the lack of interaction between streamlines in a zero-viscosity fluid, leading to indeterminate flow patterns. An alternative flow model is proposed, where a rectangle of fluid moves uniformly with the cylinder, further complicating predictions in such conditions. The challenge remains in mathematically modeling flows in a zero-viscosity scenario.
hhhmortal
Hi, I'm trying to prove D'alembert's paradox, but considering a nonviscous, irrotational flow of a fluid around a cylinder.
I used the following webpage to help me, which was very good, but I got to a part where I can't seem to solve, perhaps cause my maths needs some brushing up.
http://galileo.phys.virginia.edu/classes/311/notes/fluids1/fluids11/node19.html
It's on Equation (2.38). How do you get this from Eq 2.36 and Eq 2.37 ?
What component of velocity is being used on Eq 2.38?
Thanks.
At the surface of the cylinder (stated measurement point)
R = r so substituting
The radial velocity (cosine term) is zero.
So total velocity is given by tangential velocity (sine term) alone
substitute R = r and square and you have your next equation (2.38)
Note - D'Alembert's paradox relies on a specific flow pattern in a fluid with zero viscosity. With zero viscosity, there's no interaction between adjacent "streamlines" so flow patterns aren't determinate. An alternate, but just as valid flow pattern would consists of a long rectangle of fluid flowing at the same speed as the cylinder, with no interaction of the surrounding fluid. It all depends on the initial state of the fluid. It's not clear to me, how any mathematical model can be made to predict a flow in fluid with zero viscosity.
  • · Replies 24 ·
  • · Replies 45 ·
23K
  • · Replies 21 ·
9K
  • · Replies 33 ·
  • · Replies 48 ·
10K
31K
