Fluid Flow and Projectile Motion
Water flows through a pipe with a radius of 1 inch at 2 m/s and exits through a nozzle with a radius of 1/4 inch, resulting in a velocity of 32 m/s at the nozzle. To determine how far the water travels horizontally before hitting the ground, the time of flight from a height of 2 meters is calculated to be approximately 0.64 seconds. Using the horizontal speed of 32 m/s, the horizontal displacement is found to be 20.4 meters. The discussion emphasizes the importance of understanding fluid dynamics and projectile motion principles to solve the problem accurately. The final answer indicates the water travels 20.4 meters horizontally before impact.
dropgigawatt
Water travels through a pipe with a radius of 1 inch at a speed of 2 m/s. There is a nozzle at the end of the pipe with a radius of 1/4 inch. The pipe is horizontal and 2m above the ground. How far does the water travel in the air before hitting the ground?
r1 = 1 in.
r2 = 1/4 in.
V1 = 2 m/s
y = 2 m
A1V1=A2V2
A = ∏r2
Δx = Vxt
I found that A1 = 3.14 in.2 and A2 = .20 in.2
I plugged those in and found V2 = 31.4 m/s2.
Now I think I have to find t so I can work with Δx = Vxt but I'm not sure how to go about that or if that's even the direction I should be taking.
EDIT: I tried using kinematics, re-arranging V2 = V0^2 + 2aΔx. I plugged my values into -V0^2 / 2a = Δx and got -31.42 / 2(9.81) = 50.3 m
Would that be correct?
You did not have to. All you need is the ratio ## \frac {A_1} {A_2} = \frac { \pi r_1^2 } {\pi r_2^2 } = \left( \frac {r_1} {r_2} \right)^2 = 16 ##, so the velocity at the nozzle is 32 m/s exactly.
The result is inaccurate, and the dimension is wrong.
The rest of the problem is simple projectile motion. You know the initial velocity and the initial height. Find where it strikes the ground.
The water is traveling both horizontally and vertically. They want you to find how far it travels horizontally when it hits the ground. How long does it take for an object dropped from a height of 2 m to reach the ground? How far does an object travel horizontally in that amount of time if its horizontal speed is 32 m/s?
I got it.
t = .64 s
displacement = 32(.64) = 20.4 m
Thanks guys!
  • · Replies 38 ·
