Fluid mechanics, source-sink question
In fluid mechanics, the velocity of liquid entering or exiting a hole in a two-dimensional model is expressed as Q/(2 pi r). The discussion raises a question about the velocity in three dimensions, suggesting it may be Q/(4 pi r^2) for a point source. This formulation is confirmed as correct for three-dimensional scenarios. The conversation highlights the differences in fluid flow modeling between two and three dimensions. Understanding these principles is essential for accurate fluid dynamics analysis.
liometopum
For a point source, correct.
Thank you, Curl!
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
  • · Replies 18 ·
