Fluid Mechanics - Split Pipe Flow Question (momentum and Bernoulli eqns)
In summary: ThanksHere's my summary:In summary, the conversation is about a fluid mechanics homework problem involving a pipe with one inlet and two outlets. The problem asks for the selection of a suitable control volume and application of momentum equations in the x and y directions, calculation of the outlet pressure assuming no frictional losses, and calculation of the reaction forces in the x and y directions that must be absorbed by the support system on the junction. The conversation includes equations for mass flow rate, area, and continuity, as well as discussions about the use of Bernoulli and angular momentum equations. The solution involves applying conservation of momentum to the entire junction and sum
50Cent
33
Hi,
I am stuck on this question as I haven't encountered anything similar to it. Normally I have only dealt with pipe with one inlet/outlet.
I am given a diagram of the pipe shown on the attachment (Sorry for the crude diagram).
Hosted it while the attachment is "reviewed"
http://img443.imageshack.us/img443/2215/fluidmechqn5.th.jpg http://g.imageshack.us/thpix.php
I am told that the junction lies in the horizontal plane x-y and the gravity vector is perpendicular to this. Also, the flow rates from each outlet are equal.
Variables
Inlet Pressure = 200kPa
Inlet flowrate = 2m^3/s
diameters are shown on picture
Density of water = 1000kg/m^3
Question,
(a) I have to select a suitable control volume and apply the momentum equations fo coordinate directions X and Y
(b) Calculate the outlet pressure assuming no frictional losses
(c) Calculate the reaction forces in directions X and Y, that must be absorbed by the support system on the junction.
mass flow rate = Ro.A.U
http://www.it.iitb.ac.in/vweb/engr/civil/fluid_mech/section3/img00094.gif
Area = Pi.(R^2)
Lets denote the inlet with suffix "-I", the top outlet "-Ot" the bottom outlet "-Ob"
(a) I took the control volume at the centre so it includes the inlet and both outlets.
Before applying the momentum equations i calculated
Area-inlet = 0.25Pi
Area-top-outlet = 0.00625Pi
Area-bottom-outlet = 0.00625Pi
The mass flowrate is given as 2 so,
U-inlet = 2/(1000*0.25Pi) = 2.55x10^-3 m/s
Applying the continuity equation
U-I*A-I = U-Ot*A-Ot + U-Ob*A-Ob (Density cancels throught)
We were told that the mass flowrate was the same at each outlet. so Am i right in assuming the speed of water at Ot and Ob are the same? So i can make the RHS 2*U-O*A-O
Then rearrange and solving for U-O to get the speed of water for both outlets to be 0.0204m/s
Then using the mass flow equation:
mass flow rate = Ro.A.U-O
mass flow rate = 1000*0.0625Pi*0.0204
mass flow rate = 4 M^3/s
Then I am not sure what I am meant to be doing. Do i need to calculate the momentum in the Fx and Fy direction?
(b)
To find the pressure I am assuming i have to use the bernoulli equations. But I am not sure how to apply it to this control volume. I know the value of "z" is zero so they dissapear.
Can i say:
P-I/Ro*g + (U-I^2)/2g = [P-Ot/Ro*g + (U-Ot^2)/2g] + [P-Ob/Ro*g + (U-Ob^2)/2g] ?
then rearrange for on of the pressures on the RHS assuming they will be the same?
(c)
I know the method, but haven't got this far... need to get the first two bits done. But i would use the:
F= SQRT[ Fx^2 + Fy^2] equationAny help is much appreciated
Thanks
I should probably add, the flow is going from the LHS pipe (diameter 1m) and splitting between the two pipes (diameter 0.5m)
Hmm, I am starting to think maybe the control volume should be only across the inlet and one outlet pipe. We don't have to take into account friction factor or pipebends (90degree and 45degree etc) because we're not that far in the course. I am unsure whether i can apply the bernoulli and momentum equations between 3 points like i have attempted.
Like i said, any help would be much appreciated, even a point in the right direction is good enough for me! That way you won't have to type out the long equations :p
Thanks
I believe you will need the ANGULAR momentum equation along with the Bernoulli equation. This is a tough problem, does the problem statement mention inviscid flow? You will have a change in momentum from two different affects, the change in direction of the fluid, and its change in speed. Hopefully someone else will have a better idea of what to do for this problem cause I think I'm stuck.
Just apply conservation of momentum to the entire junction. You have mass flow rates and velocities at each inlet and oulet. Sum momentums in the x and y-directions, the difference of each is the reaction that "holds" the junction in place.
Let's assume that x is in the horizontal (as its drawn) direction. Summing momentums, you have the contribution from the inlet (the entire flow) and the x-component of the bottom outlet, realizing that there's no component in the top pipe. Sum.
You can do the same for the y-direction, realizing the only components will be the entire flow through the top outlet and the component of the bottom. Sum.
Nothing in the problem statement about inviscid flow...
Ok, thanks for your input... will give it a go, will post up what i get in a little bit :)
Thanks 2 both of you
btw, should i be taking density to be 1000 kg/m^3??
Right, this is what I've got with what you both said. Is this what you meant i should do?
http://img149.imageshack.us/img149/8679/dsc00440cf3.th.jpg http://g.imageshack.us/thpix.php
http://img149.imageshack.us/img149/3536/dsc00441mq8.th.jpg http://g.imageshack.us/thpix.php
http://img149.imageshack.us/img149/7479/dsc00442qn7.th.jpg http://g.imageshack.us/thpix.php
The bit cut off on the right is just saying the Area of outlet 2 and 3 = 0.0625*Pi
http://img149.imageshack.us/img149/787/dsc00443em2.th.jpg http://g.imageshack.us/thpix.php
http://img363.imageshack.us/img363/180/dsc00444ir2.th.jpg http://g.imageshack.us/thpix.php
http://img363.imageshack.us/img363/3987/dsc00445hi0.th.jpg http://g.imageshack.us/thpix.php
i get 199.99Kpa as my answer for the pressure at both outlets... which doesn't really seem correct to me. Surely the pressure should have increased due to the reduced cross sectional area of the pipe? Or is it due to the fact it only has half the mass flow rate passing through it?
Oh, you haven't learned Bernoulli's well enough yet. More homework problems, haha! The equation states that the total energy across a streamline stays constant. The energy can be transferred to and from pressure, velocity, and elevation. If one goes up or down, the it must be compensated for.
In your case, the problem is assumed to be planar, so you can cancel the gz (elevation) terms. The question remains: what happens to the flow as the area decreases? Does velocity increase or decrease? Based on this, what would you expect pressure to do?
Hi,
lol true, fluid mechanics isn't really my favourite module :p
In answer to your question:
As the area of the pipe decreases, for the same mass flow rate... the velocity would increase along with the pressure. right?
But seeing as the flow is being split in two, the mass flowing through each outlet would be half the total mass entering the control volume so the reduced area is sort or countered? is that right?
No no no. OK, ignore the fact that there are two pipes. As you've learned so far (neglecting friction), the geometry of the pipes is of no concern. All we're concerned about is mass flow, pressure, velocity, elevation, density.
So, what we have is a fluid coming in at 2 m/s at 200 kPa. The AREA of the pipe is 0.25. From this information we can get the mass flow. From continuity and the fact that it's steady-state, the mass flow doesn't change. Mass in = Mass out. Since we have the exit area: 0.0125 (0.00672 x 2), we can get the exit velocity. Again, it doesn't matter what the pipes look like, all we care about is that the flow exits a 0.0125 area tube.
edit: Areas not right here, didn't see the notation, exit velocity is correct though
This gives me an exit velocity of 4 m/s. This should make sense, the mass flow stays the same, so velocity must increase as a function of the ratio of areas.
Now our equation for Bernoulli's looks like this:
[tex] \frac{P}{\rho g} + \frac{V^2}{2g} = k [/tex]
Where k is a constant. When looking at a changing flow, we typically say that the initial conditions equal the final conditions, since we both equal the same constant.
However, if we look at the equation, we see that the SUM of the two pressure terms (static pressure from the first term, and dynamic pressure [think internal and kinetic energy]) must stay the same.
We have just determined that velocity increases. That increases the dynamic pressure term. To equal out, that means that the static pressure term MUST decrease. I get a final static pressure of 194kPa.
p.s. Make sure you use correct units as well, as I messed up the first time. 200kPa needs to be 200,000 Pa in the equations.
Ok, thanks for the explanation :)
About to work through what you said, one thing though...
The problem statement said the mass flow rate was 2 m^3/s, so is it correct to take the velocity as 2m/s?
I tried to calculate it as ashown here:
But i get a very small speed!
I have got different velocity and as a result different pressure. Area is decreased which in turn results in increase in velocity and therefore higher pressure. This makes sense!
I am not too bothered about getting the right answer! I think i have got correct method so hopefully I will get at least 15+.
PS: you are getting small speed because you have made one mistake! everything else is correct! look back at continuity.
Thanks for the reply.
hmm.. i can't spot my mistake..
For the velocity at the inlet (U1) I used the equation
mass flowrate = Velocity x Density x Area
We're given the mass flowrate 2 m^3/s. Density of water is 1000 kg/m^3 and the area of the inlet pipe is 0.25*Pi
so,
Velocity = (m-dot)/ (Density x Area)
= (2)/(1000)*(0.25*Pi)
Which gives us U1= 2.55 x10^-3
The only variable that i might be using wrong is the density! Because m-dot, and area are pretty much given.
The putting that into my continuity equation (After canceling density on both sides). I said that U2 = U3 as it says in the question there is an equal flow rate out of each outlet. Then rearranging i consequently get a small value for U2 and U3. Where did i go wrong?
No it doesn't. An increase in velocity will result in a decrease in pressure, not increase.
u2 > u1 ==> P2 < P1
CS
mass flow rate has units of kg/sec! (i think)
Look back at your first year notes and/or work out the units for --> dm/dt = density x area x velocity
flow rate is 2m^3/sec
i am sure you can do it now!
taking Pv = RT into consideration we can say that pressure decreases as velocity increase if T is constant... but...ARGHHHHHHHHHHHHHHHHHHHHH
SOMEONE KILL ME!
Ahhh right! Yeah got it... they gave us the volume flow rate in the question...so
http://www.ac.wwu.edu/~vawter/PhysicsNet/Topics/Pressure/FlowGifs/FluidFlow05.gif
So i get U1 = 2.55 m/s
Is that what you got?
SOMEONE KILL ME!
As i remember, the "v" in that equation stands for volume and not velocity :)
OK here are my final answers... i get:
U1 = 2.55 m/s
U2 = 5.1 m/s
U3 = 5.1 m/s
P2 = P3 = 190.2 kPa
Fx = -1495N
Fy = 1495N
yes! I know quite a few people who got the same.
and yes of course it stands for volume! -silly me! too much work, too much drinking, too much smoking! Its all having a big effect on my brain!
Cool, thanks for you help... appreciate it.
One last thing, the Fx and Fy we worked out is for the force on the control volume right?
So is the force that must be absorbed by the support system the opposite?
i.e
Fx = 1495
Fy = -1495
Might be worth a mark... not sure...
I get one of them to be negative as well :)
OK, sorry about that volume flow-velocity confusion. Took a quick glance and thought it just said m/s. However, with an area and volume flow rate (Q) you can certainly easily get the velocity.
Understanding and application of Bernoulli's Equation is the founding principle along with conservation of momentum and continuity in Fluid Mechanics. You will be wise to study it well and have complete understanding of the relationship between velocity and pressure.
No problem...
Turns out i was making a big error with the momentum equations...
have to take into account the P*A forces acting on each end of the control volume.
so i get
U1 = 2.55 m/s
U2 = 5.1 m/s
U3 = 5.1 m/s
P2 = P3 = 190.2 kPa
Fx = -132.6 kN
Fy = 12.4 kN
which makes much more sense.. the majority of the force is going to be in the x direction, as that is the direction the fluid is flowing!
1. What is fluid mechanics?
Fluid mechanics is a branch of physics that deals with the study of fluids (liquids and gases) and their behavior under different conditions. It involves understanding how fluids flow, the forces that act upon them, and how they interact with their surroundings.
2. What is split pipe flow?
Split pipe flow is a type of fluid flow where a fluid is divided into two or more streams and then recombined back into a single stream. This can occur in pipes or channels with branching or merging sections.
3. How do momentum equations apply to split pipe flow?
Momentum equations, specifically the conservation of momentum principle, apply to split pipe flow by describing how the total momentum of a fluid system remains constant, even when the fluid is divided and recombined. This principle can be used to calculate the velocity and flow rate of the fluid in each section of the split pipe.
4. What is the Bernoulli equation and how does it relate to split pipe flow?
The Bernoulli equation is a fundamental equation in fluid mechanics that describes the relationship between fluid pressure, velocity, and elevation. It states that as the velocity of a fluid increases, the pressure decreases. In split pipe flow, the Bernoulli equation can be used to calculate the pressure differences between the different sections of the pipe.
5. How is split pipe flow used in real-world applications?
Split pipe flow has many practical applications, such as in chemical and industrial processes, water distribution systems, and hydraulic systems. It is also used in the design of ventilation and air conditioning systems, as well as in the study of blood flow in the human body.
  • Classical Physics
  • Mechanical Engineering
