Fluid Velocity and Pressure in a *Closed* System
4 replies · 5K views
joh_eng
In a closed fluidic system (with a pump), fluid velocity is constant throughout the system but what puzzles me is the pressure drop due to viscous effect. In a horizontal pipe, pressure decreases gradually (assuming low friction) down the pipe due to viscous effect. In this concepts, it's hard to comprehend constant velocity (=constant flowrate). In Bernoulli's principles, where total energy is constant along the streamline, if there is pressure drop (static) in a horizontal pipe (where potential energy is zero), dynamic pressure is increased meaning velocity has increased. Can someone pinpoint what I am missing here? Thanks.
Welcome to the PF. :smile:
That is incorrect. Would you like to put additional constraints on the diameter of the pipes carrying this flow to make that statement true? :smile:
joh_eng said:
In a closed fluidic system (with a pump), fluid velocity is constant throughout the system...
Clarification: this is true with a constant pipe size, but more generally (with a variable pipe size), it is volumetric flow rate that is constant...
... but what puzzles me is the pressure drop due to viscous effect. In a horizontal pipe, pressure decreases gradually (assuming low friction) down the pipe due to viscous effect. In this concepts, it's hard to comprehend constant velocity (=constant flowrate). In Bernoulli's principles, where total energy is constant along the streamline, if there is pressure drop (static) in a horizontal pipe (where potential energy is zero), dynamic pressure is increased meaning velocity has increased. Can someone pinpoint what I am missing here? Thanks.
Simply put, the basic versions of Bernoulli's equation don't apply. Bernoulli's equation is a conservation of flow energy statement, so it requires lossless and therefore inviscid flow.
But you can add a term to Bernoulli's equation to represent the loss and preserve the conservation of energy in a real-world situation. Welcome to my world!
http://my.me.queensu.ca/People/Sellens/LossesinPipes.html
Then, fluid velocity increases which increases dynamic pressure to decrease static pressure? Thanks
I believe this is correct if diameter is constant. Constant velocity and diameter --> constant flowrate throughout the system
