What Characteristic Length Should Be Used for Fluids in Low Gravity?
The discussion centers on determining the appropriate characteristic length (L) for fluids in low gravity, specifically in relation to their natural oscillation frequency, defined by the formula ##\lambda = \sqrt{\sigma / (\rho L^3)}##. Participants debate whether L should be defined as the diameter (D) or radius (r) of a sphere, and how it varies for different geometries such as channels. It is established that the characteristic dimension is influenced by the vibration mode, which affects the oscillation frequency of the fluid.
  • Understanding of fluid dynamics principles
  • Familiarity with oscillation frequency calculations
  • Knowledge of surface tension and density concepts
  • Basic grasp of geometric dimensions in physics
  • Research the impact of vibration modes on fluid behavior in low gravity environments
  • Study the relationship between characteristic length and oscillation frequency in various geometries
  • Explore advanced fluid dynamics simulations using software like ANSYS Fluent
  • Investigate experimental methods for measuring fluid oscillations in microgravity conditions
Researchers in fluid dynamics, aerospace engineers, and physicists studying the behavior of fluids in low gravity environments will benefit from this discussion.
member 428835
Hi PF!
Fluids in low gravity have a natural oscillation frequency ##\lambda = \sqrt{\sigma / (\rho L^3)}##, where ##\sigma## is surface tension, ##\rho## density, ##L## characteristic length.
Then given a particular object, say a sphere, is ##L=D## or ##L=r##? How about a channel; would ##L## be the length, width, or height, or what about, say, half-width? Any help is greatly appreciated!
The characteristic dimension will depend on the vibration mode. For example, look here.
https://saviot.cnrs.fr/lamb/index.en.html
A sphere has entire families of vibration modes. Each one will have a different frequency because it involves different masses doing different things.
Thanks for responding. I don't really see how to distinguish between using the radius vs diameter though.
  • · Replies 19 ·
  • · Replies 18 ·
12K
