How can the required force to open the gate be calculated?
  • Thread starter Thread starter St3ph3n
    Fluids Mechanics
To calculate the required force to open a vertically hinged floodgate, the pressure difference between the water and the sub-atmospheric pressure in the outflow pipe must be considered. The force acting on the gate due to water pressure is calculated using the formula F = ρghgA, resulting in a force of 34.65 kN. The center of pressure is determined to be at a depth of 4.51 m from the hinge. To find the required horizontal force, moments around the hinge should be summed, taking into account the moments created by both the water pressure and the vacuum on the opposite side. This approach allows for the calculation of the unknown force necessary to open the gate.
St3ph3n
Hi, I need help with a fluid mechanics question:
A 1.5m-diameter floodgate placed vertically is 6m below the water level at it's
highest point. The gate is hinged at the top and opens into the
reservoir. Calculate the required horizontal force applied at the bottom of the gate
in order to open it when the pressure on the other side of the gate in the outflow
pipe is sub-atmospheric at -5m gauge pressure head.
The equations I used are:
F = ρghgA to calculate the magnitude of the force acting on the outside of the gate
hp = [(IG)/(hgA)]+hg to calculate at what depth the force acts.
I am able to calculate the force acting on the reservoir side of the gate to be 34.65KN and also where it acts to be 4.51m, using the above equations. After that however I'm lost. I know I probably have to take moments around the hinge using the above data to eventually calculate the required force but I'm not quite sure as how to go about that.
Any help would be greatly appreciated :)
Like you said, sum the moments about the hinge. A moment(torque) is force times distance. On one side you have the water pressure. It's moment about the hinge is its force multiplied by the distance the center of pressure is from the hinge. Because there is a slight vacuum on the other side, the vacuum also contributes to the moment in that direction. These moments are opposed by a force you are to calculate that it is represented by the force multiplied by the diameter. When equated there is one unknown, namely, the force you seek.
  • · Replies 56 ·
  • · Replies 49 ·
  • · Replies 29 ·
