Flux integral and Gauss's theorem
8 replies · 2K views · last reply
adgar
Please help me to solve this assignment.
[/B]
a) A vector field is given by v(x,y,z) = (y, x, z-x).
Calculate the flux from this field out of the unit cube, given by x,y,z = [0,1].
b) Use Gauss's theorem to calculate the same flux. Check that you get the same result.
Electric Flux: Φ = E. A .cosθ
Electric Flux: Φ = ∫ E. dA = Qencl / ε
For part a) one can calculate ∫∫ v . n dxdy, where n is the unit normalvector for the surface A, for each cube faces and add them together.
Well ?
[/B]
Take one of the faces of the unit cube and write out ##\vec v \cdot \hat n## then integrate over that face. Proceed to the next face, etc. Repeat until done !
[/B]
The flux through the face parallell to the z-axis, which I call for A1 and A2, is
Φ = ∫∫v.k dA1, where k is the normal vector in z-direction. But, what is V and dA1 now?!
Is v the z-component of the vector field?
I'm hoping someone can help walk me through this problem!
Do one face at the time. Both the face with x=1 and the face with y=1 are parallel to th z axis...
Or do you mean the face with z = 1 ? That is perpendicular to the z axis.
The normal in the z direction is the surface vector for the face with z = 1. In other words, (0,0,1)
A point on the surface is characterized by (x,y,z) = (x,y,1)
Can you now write out the integral for that face ?
