Calculating Tangential Acceleration of a Particle on a Flywheel
The discussion focuses on calculating the tangential acceleration of a particle on a flywheel with a constant angular speed of 137 rev/min that comes to rest in 2.7 hours. The correct formula for tangential acceleration is given by a_t = rα, where α must be expressed in radians/min². The participant initially miscalculated angular acceleration by not converting revolutions to radians and incorrectly incorporating extraneous data (68.5 rev/min) into their calculations. The correct angular acceleration is approximately 0.845679 rad/min², leading to the tangential acceleration calculation.
  • Understanding of angular motion and angular acceleration
  • Familiarity with the conversion between revolutions and radians
  • Knowledge of linear acceleration concepts
  • Ability to manipulate equations involving rotational dynamics
  • Learn about angular acceleration conversion from rev/min² to rad/min²
  • Study the relationship between tangential and angular acceleration in rotational dynamics
  • Explore the implications of friction and air resistance on flywheel motion
  • Investigate real-world applications of tangential acceleration in engineering systems
Students in physics or engineering, particularly those studying rotational dynamics, mechanical engineers, and anyone involved in the design or analysis of rotating machinery.
vertex78
The flywheel of a steam engine runs with a constant angular speed of 137 rev/min. When steam is shut off, the friction of the bearings and the air brings the wheel to rest in 2.7 h.
What is the magnitude of the tangential component of the linear acceleration of a particle that is located at a distance of 55 cm from the axis of rotation when the flywheel is turning at 68.5 rev/min?
a_t = r\alpha
\alpha = ((137 rev/min) /(2.7h*(60m/1h)) * 2PI = 0.845679 rev/min^2
a_t = .55m * 0.845679
I know I am not doing this correctly, I don't understand how to tie in the 68.5rev/min into the equation for the tangential component
In your first equation, it looks like you multiplied by 2pi to put it into radians, but you didn't carry the 2pi through the actual calculation, and then you still stated it in rev/min. :confused:
Why do you think your reasoning (other than what I mentioned above) isn't correct?
vertex78 said:
a_t = r\alpha
This is only true when the angular displacement is measured in radians (not revolutions). Linear acceleration is measured in terms of distance per time-squared.
I see a 2 PI term in there (good!), but you failed to use it. If you had used it, your angular acceleration would be in radians/min^2. (Since 1 revolution = 2 PI radians.)
When you recalculate the angular acceleration in terms of radians/min^2, this will give you the tangential acceleration in m/min^2.
The 68.5rev/min seems to be extraneous information. :wink: (But it does let you know that you are to find the tangential acceleration during the time that the flywheel is slowing down.)
Ok my bad on the angular acceleration equation I wrote, I am not sure what I was thinking, I had it written down on paper correctly, somehow I added in a 2PI into the equation I was using. For another question for the same problem I had to find the angular acceleration in rev/min^2. So that also ended up being my mistake, I was not converting it to rad/min^2 before using it to find tangential velocity.
Thanks for the help!
  • · Replies 21 ·
31K
