For those bored, a little math puzzle
  • Thread starter Thread starter LennoxLewis
    Puzzle
The discussion centers on determining the radius of the largest circle that can fit within one quadrant of a larger circle with a radius of 1. The proposed radius is sqrt(2)/4, which can also be expressed as 1/(1+sqrt(2)) or sqrt(2)-1. The method involves analyzing the geometry of the situation, particularly using symmetry and the properties of right triangles. The center of the incircle is positioned along the radial line that bisects the quadrant's angle at pi/4. By equating the lengths of the radii from the center of the incircle to the arc and the arms of the quadrant, the relationship 1-x=x/sqrt(2) is established, leading to the conclusion that the radius of the incircle is r=1-x. An alternative approach using Pythagorean theorem also confirms this relationship, demonstrating the geometric reasoning behind the calculations.
LennoxLewis
What is the radius of the largest circle that you can fit in one quadrant of a bigger of radius 1?
Real quick, I'm going to say sqrt(2)/4.
1/(1+sqrt(2))
PS: aka sqrt(2)-1
Rsmall = Rlarge x (20.5-1)
Gokul43201 said:
1/(1+sqrt(2))
PS: aka sqrt(2)-1
Good work, how did you get to it?
Let the radial position of the center of the incircle be x. From symmetry, this center must lie on the radial line that bisects the angle of the quadrant, i.e., the line at angle pi/4. Draw two radii of the small circle: one ending on the arc of the quadrant (running along this line at pi/4) and the other ending on one of its two arms (running normal to the arm). Equating these radii gives you 1-x=x/sqrt(2), and the radius of the incircle, r=1-x.
Right, i used a similar but less effective way. By similar means, i set up the equation (1 - x)^2 = x^2 + x^2, asin Pythagoras's rule for that triangle.
