Force and torque on a rectangular coil in a magnetic field
5 replies · 8K views
yjk91
A coil of wire consisting of 40 rectangular loops, with width 16 cm and height 30 cm, is placed in a constant magnetic field given by
B = 0.055Tx + 0.210T.z
The coil is hinged to a fixed thin rod along the y-axis (along segment da in the figure) and is originally located in the xy-plane. A current of 0.150 A runs through the wire.http://www.webassign.net/bauerphys1/27-p-051.gifWhat are the magnitude and the direction of force, Fbc, that B exerts on segment bc of the coil?
magnitude Fbc =
direction °
What are the magnitude and the direction of the torque, t, that B exerts on the coil?
magnitude t =
i am just lost
i have the formulas but I'm not sure how to find the magnitube for B
hints pleasE?
What's the formula for the force of a magnetic field on a current carrying wire of a given length?
F = ILB
yeah but B is in x and z direction so do i just do
0.15 A * 0.3 M * (0.055T x + 0.210T z)
and then do i square x and z then rad it? i tried that but it's not right
yjk91 said:
F = ILB
It's a vector equation:
[tex]\vec{F} = I \; \vec{L} \times \vec{B}[/tex]
In this case you have 40 wires of length 30cm all carrying the same current I, so multiply the result by 40.
[tex]\vec{F} = 40I \; \vec{L} \times \vec{B}[/tex]
You should be able to write vectors for both L and B and perform the cross product (do it manually, it's probably easier). The result will be your force vector.
so
40 * .15 * 0.3 X (0.055x + 0.210z)
using the cross product i get (0.3 * .21, 0 , -.3*.055)
if i add them i get 0.0465
and 40 * .15 * .0465 = .279 N
is this right?
yjk91 said:
so
is this right?
The cross product yields a vector, so you can't just add the components. You have to take the magnitude of the vector to find the magnitude of the force. First write out all three components of the force vector.
