Force and torque on a wire carrying a current
The discussion focuses on calculating the net force and torque on a wire carrying current I in a magnetic field defined by B = B0*(x/L) in the z-direction. The correct expressions for the net force and torque are derived from the fundamental equations Fnet = I*L*B*sin(α) and τnet = I*L²*B*sin(α). The user initially submitted incorrect answers due to misunderstanding the dependence of the magnetic field on the wire's length and the need for integration to account for the variable magnetic field along the wire.
  • Understanding of electromagnetism principles, specifically Lorentz force law
  • Familiarity with vector calculus and integration
  • Knowledge of magnetic fields and their effects on current-carrying conductors
  • Proficiency in using mathematical expressions for force and torque in physics
  • Study the derivation of the Lorentz force law in detail
  • Learn about integrating variable magnetic fields over current-carrying conductors
  • Explore the concept of torque in electromagnetic systems
  • Investigate applications of magnetic fields in engineering, particularly in motors and generators
Physics students, electrical engineers, and anyone studying the effects of magnetic fields on current-carrying wires will benefit from this discussion.
theKeeblerElf
A wire along the x-axis carries current I in the negative x-direction through the magnetic field
\vec{}B = B0*(x/L) \hat{}k 0\leqx\leqL
= 0 elsewhere
Part a was to draw a graph of B versus x over the interval -L\leqx\leqL, which I did.
b. Find an expression for the net force F_{\rm net} on the wire. Express your answer in terms of the variables I, L, and B0
c. Find an expression for the net torque on the wire about the point x = 0.
Fnet=I*L*B*sin\alpha
\taunet=I*L2*B*sin\alpha
I thought that because I is carried in the -\hat{}i direction and B points in the \hat{}k direction that \alpha=90 degrees, meaning I would be multiplying by 1. However, for both parts, when I submit I*L*B0 and I*L2*B0, respectively, the website says "Your answer either contains an incorrect numerical multiplier or is missing one."
For part b I've tried submitting -I*L*B0 because actually calculating I\hat{}L X \hat{}B yields a negative answer, but that didn't work either.
I've also tried to use x in my answer, and the website says the correct answer doesn't depend on it.
Any help would be much appreciated!
This is only true when the magnetic field is constant over the length of the wire. More generally, you will have to divide the wire into pieces d\textbf{l} so small that the magnetic field is effectively constant/uniform over the length of the piece, calculate the force on each piece:
d\textbf{F}=Id\textbf{l}\times\textbf{B}
and then add up (integrate) all these little forces:
\textbf{F}=\int Id\textbf{l}\times\textbf{B}
You must do something similar for the torque.
  • · Replies 21 ·
