Force between two perpendicular currents
The force between two perpendicular currents in wires is zero due to the nature of the magnetic field lines produced by each wire. According to the Biot-Savart Law, the magnetic field generated by one wire is parallel to the other wire, resulting in a net magnetic force of zero. However, there is a non-zero torque that acts to align the wires parallel to each other, as indicated by the right-hand rule (RHR). This phenomenon highlights the distinction between force and torque in electromagnetic interactions.
  • Understanding of the Biot-Savart Law
  • Familiarity with magnetic field lines
  • Knowledge of the right-hand rule (RHR)
  • Basic principles of electromagnetism
  • Study the Biot-Savart Law in detail
  • Explore the concept of torque in electromagnetic systems
  • Investigate the implications of current direction on magnetic forces
  • Learn about applications of perpendicular currents in real-world scenarios
Physics students, electrical engineers, and anyone interested in understanding the principles of electromagnetism and the interactions between current-carrying conductors.
j-so16
Why is the force of a wire to another wire that is perpendicular to it zero?
biot-savart law
its because the magnetic field lines dut to one wire will be parallel to the another wire. And as the magnetic force is ilbsin(x) ad here the x is 0.
the net force would be zero, but the net torque would not be. if you sketch this situation, and draw some field lines by one wire only (call it #2), you can use the RHR applied to wire #1, and because of #2's magnetic field, there would be a torque which would tend to make the two wires align parallel and carry current in the same direction.
  • · Replies 17 ·
