Force Between Two Wires (Magnetism)
The discussion focuses on calculating the magnetic field at point P due to two parallel wires carrying 25 A currents, positioned 13.0 cm apart. The magnetic field is determined using the formula B = (μI)/(2πd), where μ is the permeability of free space, I is the current, and d is the distance from the wire. The participant is advised to calculate the magnetic field vectors for each wire at point P and then combine these vectors to find the total magnetic field, emphasizing the need for vector addition rather than simple arithmetic addition.
  • Understanding of magnetic field calculations using Biot-Savart Law
  • Familiarity with vector addition in physics
  • Knowledge of Cartesian and cylindrical coordinate systems
  • Proficiency in trigonometry for angle calculations
  • Study the Biot-Savart Law for magnetic field calculations
  • Learn vector addition techniques in physics
  • Review coordinate transformations between cylindrical and Cartesian systems
  • Practice trigonometric applications in physics problems
Physics students, educators, and anyone preparing for exams involving electromagnetism and magnetic field calculations.
medgirl
Two long thin parallel wires 13.0 cm apart carry 25 A currents in the same direction. Determine the magnetic field at point P, 12.0 cm from one wire and 5.0 cm from the other.
(Sorry I don't have a diagram, but this is essentially a triangle, with sides of 13 cm, 12 cm, and 5 cm, and the point P is at the vertex of the 5 cm and 12 cm sides.
B= [uI]/[2pi (d)]
Ok I see that the triangle is a 5-12-13 triangle and thus the Pythagorean theorem applies. I am not sure how this impacts the solution. I obviously need to calculate B for each wire to point P, but once I obtain these values I do not now how to proceed to combine them together to find the total field at P. Simply adding them does not seem correct.
I would really appreciate some guidance. This is not homework, I am reviewing for an exam (tomorrow!) and am really stuck... Thanks!
You need to use vectors for this. The magnetic flux density from a current carrying wire is in the \hat{\phi} direction. Calculate the vector in cartesian coordinates (convert from cylindrical) at the desired point for each of the wires and then add the vectors together. The field vector will be of the form B\hat{\phi} = B(\alpha_x\hat{x}+\alpha_y\hat{y}) where the magnitude of the vector \alpha_x\hat{x}+\alpha_y\hat{y} is one.
You can also use trigonometry to find out what the direction of the fields are from each wire if you feel more comfortable doing that but it will probably involve more work.
  • · Replies 23 ·
