Force Calculation to balance arm
The discussion revolves around calculating the force required to hold a pivoted arm in position using a pneumatic ram. Participants explore the mechanics involved, including torque calculations and the effects of angles on force requirements, with a focus on the application of physics principles to a practical problem.
  • Mr. Howell presents a scenario involving a pivoted arm with a center of gravity and weight, seeking to determine the force needed from a pneumatic ram.
  • One participant suggests that the moments should be calculated about the pivot at the base of the arm, indicating a larger required ram force than initially calculated.
  • Another participant calculates the torque at the pivot and derives a force requirement, but expresses uncertainty about the correctness of their method due to a significant difference from a friend's calculation.
  • A later reply emphasizes the need to consider only the components of forces that are perpendicular to the moment arm when calculating torques.
  • Subsequent calculations are presented, with one participant arriving at a force of 1054N, expressing satisfaction with this result.
Participants express differing views on the correct method for calculating the required force, with no consensus reached on the final value or the validity of the various approaches presented.
Participants reference specific angles and distances in their calculations, but there are indications of missing assumptions or potential dependencies on definitions that remain unresolved.
gavhowe
Hello,
I am after a little help on an applicaition, I need to calculate the force require to hold a pivoted arm in a position using a pneumatic ram. Basically the arms C of G is 740mm up the arm, and the arm weights 100kg. Roughly 1000N working at an offset of 147mm. The arm is 16 degrees from vertical, with the ram at 62 degrees to the arm, so it is pulling to hold the arm in position.
I attach a diagram to give all the information
I had a friend take a look and he calculated 676N, I am not sure if this is correct. As I could not follow is method or workings. I attach them as well.
Thanks
Mr Howell
The arm is rotating around the pivot at its lower end, right? The pivot at the end of ram's shaft is there just to allow the ram / arm angle to change freely.
Moments should be taken about the pivot at the base of the arm. I see a larger ram force being required than what you (and your friend) calculated.
yes the arm is free to rotate around the pivot at the base of it. The ram will slightly change the angle of the arm when it moves in and out.
My calculation were, to first calculate the torque at the pivot:
100kg x 9.81 x 0.147m = 203.07 Nm
so 203.07 / .06m = 3384.5N to support at the pivot point of 215mm up the arm. If the ram was at 90degrees to the arm.
So need to calculate the angle from 90 degrees to the arm to the real position of the ram.
90 - 62 = 28 degrees.
3384.5 / (cos 28) = 3833.18N
But I am not happy that my method is correct as it is vastly different end figure then my friends.
Calculating torques requires that you use the components of the forces that are perpendicular to the moment arm. So, for example, the torque about the pivot point due to gravity would use the component [itex]mg \; sin(16°)[/itex].
Ok I have had another look at the problem and tried is a different way, please could some let me know if this is correct:
981N*0.74m*Sin16 = ? * 0.215m*Sin62
(981N*0.74m*Sin16) / (0.215m*Sin62)
= 1054N
= 1054N
Now THAT looks good!
thank you
  • · Replies 18 ·
  • · Replies 28 ·
  • · Replies 31 ·
10K
