Force (object is suspended connected to a block on table and pulled up)
8 replies · 8K views · last reply
~christina~
A block of mass m1 on a rough horizontal surface is connected to a ball of mass m2 by a lightweight cord over a lightweight frictionless pulley as shown. A force of magnitude F at an angle theta with the horizontal is applied to the block. The coefficient of friction between the block and surface is [tex]\mu_k[/tex]
a.) draw a free body diagram of the 2 masses
b.) use Newton's dynamic equation to determine the magnitude of the acceleration of theh 2 objects in terms of their masses, F, theta, and [tex]\mu_k[/tex]
c.) what is the tension in the cord
http://img518.imageshack.us/img518/1023/picture1dn4.png
F= ma
Ffk= uk* Fn
and a Newton's dynamic equation? ==> what is that exactly??
a)for the free body diagram
http://img484.imageshack.us/img484/2900/90134448jw8.th.jpg
b) how would I do this question...not sure and I'm stuck after the free body diagram...hm..
c) I guess I would need to solve part b to get part c
~I do know that they both have the same accelration but how would I know if the total forces [tex]\sum Fx= 0[/tex]?
I need help please..
That's Newton's 2nd law.
One problem with the FBD: That applied force F is at an angle, not horizontal.
Analyze the forces parallel to the direction of motion for each block and apply Newton's 2nd law. You'll get two equations--one for each mass--that you'll solve together for the two unknowns: the acceleration and tension.
I was wondering why I don't analyze the horizontal component of the block but I think it's b/c the total forces = 0 but...this is what I got.
for m2 (only movement in y direction)
[tex]\sum Fy= T- m_2 g= m_2 ay[/tex]
for m1 (block)
[tex]\sum Fx= max= Fcos theta- (T+ \muk m1g)[/tex]
[tex]\sum Fy= may= Fsin theta + N- mg= 0[/tex]
Well I just wanted to check first...
Good. I would just call the acceleration "a".
for m1 (block)
[tex]\sum Fx= max= Fcos theta- (T+ \mu_k m1g)[/tex]
Careful here: What's the normal force? Again: call the acceleration "a".
Good. Use this to figure out N.
[tex]\sum Fy= T- m_2 g= m_2 a[/tex]
for m1 (block)
[tex]\sum Fx= ma= Fcos theta- (T+ \muk m1g)[/tex] => was this incorrect (see below for my correction)??
~I do know that that is the Fx component right? but I guess I need to incorperate the N?
[tex]\sum Fy= ma= Fsin theta + N- mg= 0[/tex]
from the Fy
N= mg - Fsin theta
I think that since the Ffk = uk*FN
then the equation on the top for the Fx wouldn't be uk* m1g since the normal force is lighter so it would be instead
[tex]\sum Fx= ma= Fcos theta- (T+u_k (m_1g- Fsin theta))[/tex]
Is it fine now?
I guess whenever I have to find the x component of the force when there is friction I need to incorperate the normal force the angle it is being pulled at if there is a angle so that the normal force is not just m*g right?
~christina~ said:
Is it fine now?
Yes, all better.
Right. Friction depends on the normal force, which may or may not equal the weight of the object, depending upon the situation.
from the Fy
N= mg - Fsin theta
________________________________________________________________
but how would I find the part b) which is...
b) b.) use Newton's dynamic equation to determine the magnitude of the acceleration of the 2 objects in terms of their masses, F, theta, and [tex]\mu_k[/tex]
(I'm not sure what they want)
would it be adding the 2 equation??
the first object and second object's forces like this?
so adding them I get..
+ T- mg= m2a
+ Fcos theta - T- uk (m1g- Fsin theta) = m1a
Fcos theta- m2g- uk(m2g- Fsin theta)= (m1 + m2)a
a= (Fcos theta- m2g - uk(m2g- Fsin theta))/ m1+ m2
Is this what they want?
Assuming it is...
for part c.) I need to find
c.) tension in cord..
I think that I would plug this into a original equation while using the acceleration I found...
T= m2a + m2g
substituting a
T= m2( (Fcos theta- m2g - uk(m2g- Fsin theta))/ m1+ m2) + m2g
I think this is okay but not sure..
Looks good to me!
As a practical matter, I would solve for a and then plug the numerical value into the other equation to get T.
Oh okay..I would plug in the numbers if I had numbers given...
I usually find it challenging to not have numbers though..
Thanks for your help Doc Al !
