Force of a charge Q at the origin?
The discussion focuses on calculating the net force on a charge Q located at the origin, influenced by two other charges: Q at (0,b) and 2Q at (0,-2b). Participants emphasize the application of Coulomb's Law, which states that the force F between two charges is given by F = kqQ/d², where k is Coulomb's constant. The net force on charge Q is determined by vector addition of the forces exerted by the other two charges, considering their directions. The conversation highlights the importance of understanding vector forces and the impact of charge and distance on the magnitude of the resultant force.
  • Coulomb's Law (F = kqQ/d²)
  • Vector addition of forces
  • Understanding of electric charge interactions
  • Free-body diagram construction
  • Learn how to construct and analyze free-body diagrams for multiple forces
  • Study the implications of charge and distance on electric force magnitude
  • Explore vector addition techniques in physics
  • Investigate the concept of electric field strength and its relation to force
Students studying electrostatics, physics educators, and anyone interested in understanding the principles of electric forces and charge interactions.
Violagirl
A charge Q is placed at the center of the origin on the attached document. What is the force on this charge?
Coulomb's Law:
F= kqQ/d2 ^
r
See attached document for figure. I'm confused by this problem. Along the positive y axis, we have a positive charge of Q. On the negative y axis, we have 2Q, which I also assume is a positive charge. Hence because Q at the origin is also at the center, I thought that both charges would repel this Q to stay at the center because like charges repel each other. I'm not sure how to show this though with Coloumb's Law since from that point of view, Q isn't going anywhere so there would be no change in distance...
In your expression for Coulombs law, you forgot that force is a vector.
How would you normally handle two forces that point in opposite directions?
Well, thinking of it as a vector, we have a force from Q at origin to Q going upward. And then there's a second force from Q at origin to 2Q for where 2Q has a vector pointing downward. So would I find the difference between the vectors of both charges and use Coloumb's Law twice in the problem for both situations and then subtract the equations for both?
Well done.
Just some pointers...
It's hard to talk about isn't it. It can help to rewrite the question in more precise terms...
Lets set normal cartesian x-y axis, then fixed charges p=+Q and r=+2Q at at position (0,b) and (0,-2b) respectively.
You want to know the net force on charge q=+Q at position (0,0).
You can draw a free-body diagram for charge q
... the force on q due to r is Fr, and it points which way?
... the force on q due to p is Fp, and it points which way?
The net force in the +y direction is given by... F(net)=...
Interestingly you don't need to apply the Coulombs law equation and the algebra etc to see what will happen.
You can use what you know of the consequences...
twice the charge= how many times the force?
but: twice the distance = how many times the force?
... so: if you double the charge and also double the distance, how many times the force?
... so Fr is how many times Fp?
Thank you so much for your input! If you increase distance between two charged points, you will greatly reduce the impact of the force. Increasing the charge with an increase in distance will still reduce how much force is generated between both points.
"greatly reduce"? How many times? Can you put a number on that?
This is actually the core lesson yu are supposed to learn from the exercize.
Note: you can still increase the charge and the distance and still have increased force.
("impact of force" and "force" are the same thing - but I think you mean "magnitude of force".)
  • · Replies 24 ·
  • · Replies 16 ·
