Force Problem with football punter
  • Thread starter Claymore
    Force
4 replies · 12K views · last reply
Claymore
[SOLVED] Force Problem
2. A football punter accelerates a football from rest to a speed of 10m/s during the time in which his toe is in contact with the ball (about 0.20sec). If the football has a mass of 0.50kg, what average force does the punter exert on the ball?
so far i have this and can't seem to find the equation(s) but i got some and does not correspond with the correct answer.
a=10ms/^2
t=.20sec
m=.50kg
F= that's what we need for answer
so F=ma
but i don't understand how we put our time in an equation to solve for Force, I know I am missing something but i don't know what. I have the answer, answer only which does not help at all :P. Thats to check whether we get the correct problem
F = ma
F = 10m/s (.50kg)
F = 5N (?) but answer that was given was 25 N
I want to know how to do it :P even thou teacher gives us answer for homework. Which is the most important thing
I'm stuck with this help
Thank you in advance
F = 10m/s (.50kg) is velocity * mass or mv which is the final momentum.
F = dp/dt or m dv/dt so take mass * (change in v)/(change in time)
a = dv/dt
a = dv/dt
so F=ma:
F= 10ms/(.50kg) = 5 m/s correct which equals Velocity(?)
so for F= dp/dt what is dp? change in P(?) / change in time so we get
F= 5ms/.20s = 25N
my question comes from F=dp/dt we use that equation to find out Force? Where can we say that F=dp/dt (as u used) comes from?
srry if i sound confusing
p = m v = momentum.
Now let's take the case for constant mass.
F = dp/dt = d (mv) /dt = m dv/dt = m a
Back the problem.
m = 0.5 kg, which is accelerated from rest (v=0) such that at the end of 0.2 s, the mass has a velocity 10 m/s. So the change in velocity (dv) = 10 m/s - 0 m/s, and the change it time (or time interval), dt = 0.2 s.
so F = ma = m dv/dt
m = 0.5 kg, dv = 10 m/s, and dt = 0.2 s
