Solving Force Questions: Mass, Acceleration & Breaking Force
  • Thread starter Thread starter terpsgirl
    Force
This discussion focuses on solving physics problems involving mass, acceleration, and breaking force. The first problem calculates the time required to stop a 2,000 kg car moving at 80.0 km/hr with a braking force of 8,000 N, ultimately determining the stopping time to be approximately 5.56 seconds. The second problem involves calculating the tension in a string required to whirl a 1,000 g stone at 5.00 m/s in a circular path of 50.0 cm, utilizing the formula F = mv²/r. Participants emphasize the importance of using consistent units, specifically kilograms, meters, and seconds.
  • Understanding of Newton's second law (F = ma)
  • Knowledge of kinematic equations
  • Familiarity with circular motion concepts
  • Ability to convert units (e.g., grams to kilograms, km/hr to m/s)
  • Study the application of Newton's second law in various scenarios
  • Learn about kinematic equations and their applications in motion problems
  • Explore circular motion dynamics and the derivation of tension in strings
  • Practice unit conversion techniques for physics calculations
Students studying physics, educators teaching mechanics, and anyone interested in understanding the principles of motion and forces in real-world applications.
terpsgirl
I'm not sure what equation is used on this particular problem.
How much time would be requird to stop a 2,000 kg car that is moving at 80.0 km/hr if the braking force is 8,000 N?
I know...
Mass 2000 kg
Acceleration is 80.0 km/hr
Breaking force is 8,000 N
What tension must a 50.0 cm length of string support in order to whirl an attached 1,000.0 gram stone in a circular path at 5.00 m/s?
I used the formula F= mv^2/ r
= (1,000.0 g) (5.00 m/s)/ 50.0 cm
= 1,000.0 x 5.00 g*m/s
____________________
50.0
I wanted to know if I was tackling this question correctly..if not what am I doing wrong?
THX!
I know...
Mass 2000 kg
80 km/hr is the velocity, not the acceleration. Just use Newton's second law and some kinematics and you should solve this problem easily.
50.0
You might want to check the units on that again. I suggest you stick to kg, m, and s.
terpsgirl...for the first problem...use the equation that states that impulse = change in momentum...the equation is:
Force * time = change in velocity * mass.
Think of what the original velocity is, and the final velocity...and u should be able to find the change in the velocity. Basically plug in your results...and solve for time.
for the second problem...i would check ur units...notice what unit ur expressing r in...and look at the units ur measuring speed in. Remeber that u should measure everything in kg's, meters and seconds.
First convert to the correct units.
Car = 2000kg.
Speed = 22.22... m/s.
Braking force = 8000N.
Using F=MA. 8000=2000A, the 8000N force acting against the car will create a deceleration of magnitude 8000/2000, thus, a = -4m/s/s.
U = 22.22..., V = 0, a = -4, t = ?
V = u + at
0 = (200/9) + (-4t)
(200/9) = 4t
t = 5, 5/9 seconds
= 5.56 seconds (2dp)
50.0
THX!
I haven't studied the concept used in question 2, but the equation looks like it would be effective. However, [always] convert to more useful units. You should be working in m/s, kgs, Ns and M.
  • · Replies 25 ·
