Force required for cutting sheet metal
- Thread starter eng_taha_a
- Start date
- Tags
- Cutting Force Metal Sheet metal
The discussion revolves around calculating the force required to cut sheet metal using an electrically powered shear machine. Participants explore various factors influencing the cutting force, including blade angle, material thickness, ultimate tensile strength (UTS), and the geometry of the cutting area. The conversation includes technical calculations and considerations related to the design of the cutting mechanism.
- Technical explanation
- Mathematical reasoning
- Debate/contested
- Some participants note that the blade angle to the cutting surface is not constant, which may increase the required cutting force as the shearing process progresses.
- One participant suggests calculating the cutting force based on the length of the blade in contact with the metal and the shear force equation.
- There is a discussion about how the clearance between the punch and die affects cut quality and the calculation of cutting force.
- Participants propose using the formula for peak punch force, which involves UTS and the area being sheared, but there is uncertainty about how to define the area accurately.
- Some participants express the need for additional dimensions to validate calculations, particularly regarding the height of the sheet above the hinge and the depth of the blade.
- One participant suggests a conservative estimate for the cutting force based on professional judgment, while another emphasizes the need for precise calculations.
- There are discussions about the mechanical advantage of the electric cutter and how it will be powered, indicating a need for clarity on design specifics.
- Several participants encourage sketching to clarify the cutting process and dimensions involved, highlighting the importance of visual aids in understanding the problem.
Participants express differing views on the calculations and assumptions regarding the cutting force. There is no consensus on the exact force required, as various factors and uncertainties are acknowledged throughout the discussion.
Participants mention limitations in their calculations due to missing dimensions and the complexity of the cutting angle. The discussion reflects a reliance on estimates and professional judgment in the absence of precise formulas for the specific cutting scenario presented.
Individuals interested in mechanical engineering, manufacturing processes, and those working with cutting tools or machinery may find this discussion relevant.
- 781
- 529
- 1,532
- 462
- 10,546
- 2,324
- 2,462
- 3,581
That same source, Manufacturing Processes for Engineering Materials, by Kalpakjian, estimates peak punch force at 0.7 X UTS X A, where:
UTS = ultimate tensile strength
A = area being sheared
- 2,324
- 2,462
- 3,581
- 17
- 0
so what is the cutting force required ?
will it be 420875 N or less or more ?
- 10,546
- 2,324
- 1,532
- 462
- 17
- 0
CAN YOU MAKE IT MORE CLEARCWatters said:Make the drawing I suggested in #4 to work out the length of the blade in the metal.
SORRY
- 10,546
- 2,324
Draw the blade at the point where the cut just reaches the edge of the sheet furthest from the hinge.
Post a sketch and I will tell you if it is correct.
- 2,462
- 3,581
- 10,546
- 2,324
- 17
- 0
- 10,546
- 2,324
- 10,546
- 2,324
eng_taha_a said:but if so the area of this triangle is too small because the sheet thickness is 1.5 mm so if the area is 8 mm2, UTS is 370 n/mm2 then the force = 0.7*370*8 = 2072 N is it right ?
I cannot check your calculation without more dimensions. For example I need the height of the sheet above the hinge and the depth of the blade below the hinge.
If the area of the triangle is 8mm2 and the height is 1.5mm then the base must be 10.7mm. That means the blade angle in that position is about...
Tan^-1(1.5/10.7) = 8 degrees.
The force you calculated would be the force required at the cutting point which is roughly 1300mm from the hinge. The force on the blade handle would be less due to leverage.
- 2,462
- 3,581
In a case like this, where we do not have an exact calculation, we have to rely on professional judgement. We also want to be conservative, but not ridiculously so. I would design for a cutting force of 2000 lbs = 9000 N.
Design all parts so that the deflection under load will not cause the moving blade to spring away from the fixed blade (see the diagrams in Post #5). I do not have a calculation for the sideways force pushing the moving blade away from the fixed blade, so I'll make a WAG and guess it to be half the cutting force, or 1000 lbs = 4500 N. The moving blade should not spring away from the fixed blade more than 10% of the sheet thickness, or 0.15 mm = 0.006" under a 2000 lb cutting force.
The above numbers seem realistic based on my experience attempting to cut 16 gauge sheet metal with a pair of tin snips. It worked for a very small piece, but on a larger piece I gave up and used a hacksaw.
- 10,546
- 2,324
jrmichler said:The equation I quoted from Kalpakjian is for the cutting edge of the moving blade parallel to the cutting edge of the fixed blade, not the inclined cut here.
The angle is pretty shallow so might not be far off.
- 1,532
- 462
- 10,546
- 2,324
- 17
- 0
- 10,546
- 2,324
- 1,532
- 462
- 17
- 0
- 16,964
- 10,545
ISBN 978-0-7506-8531-3
See chapter 5; Slice-Push Ratio.
Oblique Cutting and Curved Blades, Scissors, Guillotining and Drilling.
- Replies
- 1
- Views
- 1K
- · Replies 3 ·
- Replies
- 3
- Views
- 2K
- · Replies 10 ·
- Replies
- 10
- Views
- 2K
- · Replies 2 ·
- Replies
- 2
- Views
- 3K
- · Replies 11 ·
- Replies
- 11
- Views
- 4K
- · Replies 6 ·
- Replies
- 6
- Views
- 4K
- · Replies 4 ·
- Replies
- 4
- Views
- 2K
- Replies
- 5
- Views
- 2K
- Replies
- 5
- Views
- 4K
- Replies
- 4
- Views
- 4K
