Why is the friction force at A not considered in forces in equilibrium?
The discussion centers on the omission of the friction force at point A when resolving forces in equilibrium for a system involving a rod and a block. The hinge at point A is fixed, meaning it does not allow for sliding friction, which justifies the exclusion of the friction force in the horizontal force resolution. The horizontal reaction at the hinge counteracts any applied horizontal forces, but does not affect the block's equilibrium since the system remains static. The analysis focuses on the block's free body diagram (FBD), where only external forces acting directly on the block are considered relevant.
  • Understanding of static equilibrium principles
  • Knowledge of free body diagrams (FBD)
  • Familiarity with hinge constraints in mechanics
  • Basic concepts of forces and moments
  • Study the principles of static equilibrium in mechanical systems
  • Learn how to construct and analyze free body diagrams (FBD)
  • Explore the effects of hinge constraints on force resolution
  • Investigate the relationship between moments and equilibrium in rigid bodies
Students of physics, particularly those studying mechanics, engineers analyzing static systems, and educators looking to clarify concepts of equilibrium and force resolution.
Faiq
[moderator note: Post edited to make problem statement images visible]
https://www.physicsforums.com/attachments/question-jpg.113056/
My question is when forces are resolved horizontally, why is the friction force at A not taken into account?
Find the value of u (in terms of W)
Note:- The W next to u in the picture is actually Reaction at D, R(d)
Given solution:
https://www.physicsforums.com/attachments/forces-answer-jpg.113057/
In the given solution, why is the friction force at A not taken into account?
Moderator note: Thread cleaned up after amending the original post to clarify the problem.
I just want to know when they resolved the forces horizontally, why does their answer makes sense even though they didnt include the frictional force at point A
If you read the problem statement (which is now visible :smile:) , how is the rod joined to the plane at point A?
By a hinge
Faiq said:
By a hinge
Right. The hinge will be attached (probably bolted) to the floor. No sliding friction involved, the rod is firmly attached.
Oh but there will still be a reaction at the hinge and we have to take account the horizontal component of that
Since it is fixed its horizontal reaction will be equal to and opposite of any horizontal force applied to it.
My interpretation of the shown solution is that they were concentrating on the block's FBD, where the local friction has to counter the other external forces applied to the block.
So even if there was a resultant horizontal force at A, it won't effect the block?
Not if the system is in equilibrium. Only forces applied directly to the block affect the block.
But the force at A will effect the rod which will effect the block
The rod does not move. Nothing moves. How can the force at A affect how the rod presses on the block? That was determined by taking moments about A.
It is enough to know that the rod cannot slip at A.
oh Okay thank you. Can you also help me in another question
Start a new thread for it and I or someone else will be happy to help.
  • · Replies 90 ·
  • · Replies 42 ·
