Formula for atmostpheric pressure
  • Thread starter Thread starter mattmns
    Formula Pressure
The discussion centers on the formula for atmospheric pressure as a function of height, specifically addressing the barometric formula: p(h) = exp(-ρ0gh/p0). Key contributors mention the importance of understanding temperature gradients and the specific gas constant (R) for air, which is 287 J/(kg·K). The conversation also highlights the significance of using standard atmospheric tables for accurate pressure values at various altitudes, particularly below 11 km, as outlined in John Anderson's "Introduction to Flight."
  • Understanding of the barometric formula and its application
  • Familiarity with temperature gradients in atmospheric science
  • Knowledge of the specific gas constant (R) for air
  • Basic principles of fluid dynamics and thermodynamics
  • Research the derivation and applications of the barometric formula
  • Study temperature gradient effects on atmospheric pressure
  • Explore the role of the specific gas constant in thermodynamic calculations
  • Examine standard atmosphere tables for various altitudes
Aerospace engineers, atmospheric scientists, and students studying fluid dynamics will benefit from this discussion, particularly those interested in atmospheric pressure calculations and thermodynamic principles.
mattmns
IS there a formula for atmospheric pressure based on height? Should I have posted this in another section?
It depends on the range of heights you're looking for. The pressures, temperatures, and densities are variable, but can be approxomated into zones (one of the reasons they have names like Troposphere, Ionosphere, etc.)
Your best bet is to go to a standard atmosphere table to get mean values for the hights you're designing for.
I don't know if there is one online, but I do know there is one in the appendices of Introduction to Flight by John Anderson.
I found the formula for low (less than 11km) altitudes.
\frac{p}{p_1} = \frac{T}{T_1}^{-\frac{g_0}{aR}}
in the low altitude you are in a temperature gradient region, and T varies with altitude like T = T_1+a(h-h1)
g_0 is the acceleration of gravity at sea level
R is the gas constant (287 for air in SI units)
a is the slope of the temperature gradient, equal to -6.5e-3 K/m for the low altitude gradient.
for p1 and T1, you use the pressure and temperature at standard atmospheric sea level conditions: 1 atm and 288.16K.
h1 is 0m for this gradient region
Originally posted by enigma
(snip)R is the gas constant (287 for air in SI units)(snip)
Huh? This is a new one --- do aeros tabulate separate "R" values for different gases?
I didn't have the big cap R.
It's the ideal gas constant divided by the molecular mass.
EDIT: sorry, should have called it the specific gas constant
and no, we don't usually tabulate the R's, but we do need to know the molecular masses of commonly used fluids.
(I hate it when people sidetrack threads, but this is intriguing.)
The "specific gas constant" is useful/expedient in what sort of applications then? Jet/nozzle flow?
Yeah,
Everything from the calculation for the speed of sound
a=\sqrt{\gamma * \frac{R}{m} * T}
to the calculations of flame temperature (through Cp and Cv)
(more lengthy than I really want to enter into the Latex editor)
Has this ever resulted in confusing situations? Someone taking the "specific gas constant" for one system as being really a constant and applying it to another system?
:wink:
*thinks back to Intro to Aerodynamics*
-YES!
seriously though, the only time I ever use the ideal gas constant is right before I divide it by the molecular mass. I can't think of a single time in the last 2 years where it's been standing alone.
It is used merely to bring the ideal gas constant into "human sized" units: switching from J/(kg mol*K) into J/kg*K
Methinks I'll open a new thread in aero in a couple days --- there are a couple questions that need to ferment a bit.
Should not be too confusing, so long as you understand which units you are using.
Nautica
mattmns,
what you're looking for is probably the formula
(symbols should be obvious).
This is called the barometric formula.
  • · Replies 16 ·
