Unveiling the Proof of Induced EMF Formula: E = ∫ (v x B) · dl
The formula for induced electromotive force (EMF), represented as E = ∫ (v x B) · dl, is derived from Maxwell's equations, specifically through the application of Faraday's Law. This relationship illustrates that the EMF can be calculated by integrating the electric field and the cross product of velocity and magnetic field over a path. The discussion confirms that this formula is universally applicable, although for a closed loop, the EMF equals zero. The derivation involves using Reynolds' transport theorem to account for time-dependent surfaces in the context of magnetic flux.
  • Understanding of Maxwell's equations
  • Familiarity with Faraday's Law of electromagnetic induction
  • Knowledge of vector calculus, particularly line integrals
  • Concept of magnetic flux and its time dependence
  • Study the derivation of Faraday's Law from Maxwell's equations
  • Learn about Reynolds' transport theorem and its applications in electromagnetism
  • Explore the implications of the Lorentz force in electromagnetic systems
  • Investigate the relationship between electric fields and magnetic fields in dynamic systems
Physicists, electrical engineers, and students studying electromagnetism who seek a deeper understanding of the principles governing induced EMF and its derivation from fundamental laws of physics.
phantomvommand
TL;DR
Why is ##E = \int (\vec v \times \vec B) \cdot d \vec l##?
Why is ##E = \int (\vec v \times \vec B) \cdot d \vec l##? This seems to be a general formula, and I would like to know its proof.
Thanks for all the help.
Are you familiar with the Lorentz force ?
Then the energy per unit charge (in SI units: Joule/Coulomb) follows from ##\int {\vec F\over q} \cdot d\vec l## .
PS it's a bit confusing to use the symbol ##E## for this; it's actually a potential difference (or emf)
$$\text {EMF} = V_{AB} = \int_A^B {\vec F\over q} \cdot d\vec l $$##\ ##
Then the energy per unit charge (in SI units: Joule/Coulomb) follows from ##\int \vec F \cdot d\vec l## .
Yes, I am. Thanks for the help, I never realized this connection. I suppose this formula can be used in general? Would I be more accurate to use a loop integral instead of an integral?
The expression is correct, so it should be universally applicable (but for a loop I expect to get 0 : ##\ V_{AA}\equiv 0## ) .
Check out a few of the sections in the link (Force on a current-carrying wire, EMF).
As anything in electrodynamics the formula can be derived from Maxwell's equations in differential form, which are always valid. Here one integrates Faraday's Law (in SI units)
$$\vec{\nabla} \times \vec{E}=-\partial_t \vec{B}$$
over a surface ##A## with boundary curve ##\partial A## with the usual orientation of the path given by the right-hand rule.
$$\int_A \mathrm{d}^2 \vec{f} \cdot \vec{\nabla} \times \vec{E}=\int_{\partial A} \mathrm{d} \vec{r} \cdot \vec{E}=-\int_A \mathrm{d}^2 \vec{f} \cdot \partial_t \vec{B}.$$
Now the usual integral form of Faraday's Law is written in terms of the magnetic flux
$$\Phi_{B}=\int_{A} \mathrm{d}^2 \vec{f} \cdot \vec{B}.$$
If now the surface ##A## and its boundary ##\partial A## are time-dependent you have to use Reynold's transport theorem for surface integrals to take the time derivative. Together with ##\vec{\nabla} \cdot \vec{B}## this leads to the ONLY generally correct form of Faraday's Law in integral form:
$$\mathcal{E}=\int_{\partial A} \mathrm{d} \vec{r} \cdot (\vec{E}+\vec{v} \times \vec{B})=-\dot{\Phi}_B=-\frac{\mathrm{d}}{\mathrm{d} t} \Phi_B.$$
For a derivation of the corresponding Reynold's transport theorem, see
https://en.wikipedia.org/wiki/Faraday's_law_of_induction#Proof
  • · Replies 51 ·
9K
