Forward difference operator [SOLVED] Forward difference operator
10 replies · 6K views · last reply
foxjwill
I was looking on Wikipedia and noticed that it said that [tex]\Delta_h[/tex] could be written as
[tex] \begin{align*}<br /> \Delta_h &= \sum_{n=0}^\infty \frac{(hD)^n}{n!}\\<br /> &= e^{hD} - 1<br /> \end{align*}[/tex]
where [tex]D[/tex] is just the standard derivative. What I don't understand is how they came up with the infinite series.
Ok, so I tried going at it this way:
[tex] \begin{align}<br /> f(x+h) &= f(h) + (x+h)Df(h)+ \dfrac{(x+h)^2 D^2 f(h)}{2!} + \cdots\\<br /> f(x) &= f(0) + xDf(0) + \dfrac{x^2 D^2 f(0)}{2!} + \cdots<br /> \end{align}[/tex]
However, when I try subtracting (2) from (1), the terms don't cancel out because (1) is in terms of [tex]f(h)[/tex] and (2) is in terms of [tex]f(0)[/tex]. What should I do?
Trying to express [itex]\Delta_h f(x)[/itex] in terms of [itex]\Delta_h f(0)[/itex] seems like an odd thing to do; I'm sure there's an interesting result to be derived, but I don't see why it would relate to the question you're trying to solve.
Incidentally, your Taylor series in (1) is incorrect.
Hurkyl said:
Trying to express [itex]\Delta_h f(x)[/itex] in terms of f(0) and f(h) seems like an odd thing to do...
I was using the tailor series expansion. Do you have any other ideas?
I've added more to my previous post.
I don't have any new ideas; what's wrong with the one I already gave?
As Hurkyl said, the Taylor series expansion for the first one is wrong.
The Taylor series for f(x), expanded around x= a, is
[tex]f(a)+ f'(a)(x-a)+ f"(a)/2 (x-a)^2+ /cdot/cdot/cdot+ f^{(n)}(a)(x- a)^n+ \cdot\cdot\cdot[/tex]
If you are expanding f(x+h) about x= h, then it would be
[tex]f(h)+ f'(a)((x+h)-h)+ f"(h)/2 ((x+h)-h)^2+ /cdot/cdot/cdot+ f^{(n)}(h)((x+h)- h)^n+ /dot/cdot/cdot[/tex]
[tex]= [tex]f(h)+ f'(a)(x)+ f"(a)/2 x^2+ /cdot/cdot/cdot+ f^{(n)}(h)x^n\cdot\cdot\cdot[/tex]<br /> <br /> If you are expanding f(x+h) about x= 0, then it would be<br /> [tex]f(0+ f'(0)(x+h)+ f"(0)/2 (x+y)^2+ /cdot/cdot/cdot+ f^{(n)}(0)(x+y)^n+ \cdot\cdot\cdot[/tex][/tex]
Ok, so I fixed your [tex]\LaTeX[/tex]:
[tex]f(a) + f'(a)(x-a) + \frac{f''(a)}{2}(x-a)^2 + \cdots + f^{(n)}(a)(x-a)^n + \cdots[/tex]
[tex]f(h) + f'(a)((x+h)-h) + \frac{f''(h)}{2} ((x+h)-h)^2 + \cdots + f^{(n)}(h) ((x+h)-h)^n + \cdots[/tex]
[tex]= f(h) + f'(a)(x) + \frac{f''(a)}{2} x^2 + \cdots + f^{(n)}(h) x^n + \cdots[/tex]
[tex]f(0) + f'(0)(x+h) + \frac{f''(0)}{2}(x+y)^2 + \cdots + f^{(n)}(0)(x+y)^n + \cdots[/tex]
I'm not really sure how you got the expansions to be those. Could you explain?
[tex]\Delta_h(f(x))=f(x+h)-f(x)\Rightarrow \Delta_h(f(x))=\left(T_h-I\right)\,f(x)\quad \text{with} \quad T_h f(x)=f(x+h)[/tex]
Expanding [itex]f(x+h)[/itex] around [itex]\alpha=h[/itex] we have
[tex]f(x+h)=f(h)+\frac{1}{1!}\,f'(h)\,x+\frac{1}{2!}\,f''(h)\,x^2+\dots+\frac{1}{n!}\,f^{(n)}(h)\,x^n+\dots\Rightarrow f(x+h)=\sum_{n=0}^\infty\frac{x^n}{n!}\,f^{(n)}(h)\Rightarrow f(x+h)=\sum_{n=0}^\infty\frac{h^n}{n!}\,f^{(n)}(x)[/tex]
where at the last equality I changed the roles of [itex]x,\,h[/itex] since they are just labels. This equality can be written as
[tex]f(x+h)=\left(\sum_{n=0}^\infty\frac{(h\,D)^n}{n!}\right)\,f(x)[/tex]
and from here you have the desired result.
