Four velocity with the Schwarzchild metric
The discussion focuses on calculating the components of the four-velocity \( U^u \) for a massive particle moving radially above Earth, utilizing the Schwarzschild metric. The metric is given by \( ds^2 = -(1 + 2\Phi)dt^2 + (1 + 2\Phi)^{-1}dr^2 + r^2d\Omega^2 \). The user initially calculated \( U^0 \) as \( (1 + 2\Phi)(-1/2) \) using the normalization condition \( g_{uv} U^u U^v = -1 \). The confusion arose when attempting to isolate \( U^1 \), which was clarified by noting that the equation involves summation over both indices, thus requiring consideration of both \( U^0 \) and \( U^1 \) simultaneously.
  • Understanding of four-velocity in general relativity
  • Familiarity with the Schwarzschild metric
  • Knowledge of tensor notation and summation conventions
  • Basic principles of gravitational potential \( \Phi \)
  • Review the derivation of four-velocity components in curved spacetime
  • Study the implications of the normalization condition for four-vectors
  • Explore the role of the Schwarzschild metric in general relativity
  • Investigate the physical interpretation of gravitational potential \( \Phi \) in relativistic contexts
Students and researchers in theoretical physics, particularly those studying general relativity and the dynamics of particles in gravitational fields.
Pogags
I am trying to solve the following problem but have gotten stuck.
Consider a massive particle moving in the radial direction above the Earth, not necessarily on a geodesic, with instantaneous velocity
v = dr/dt
Both θ and φ can be taken as constant. Calculate the components of the four-velocity Uu in terms of v using the normalization condition for Uu. Do not make any approximations yet.
We are using the metric:
ds2=-(1+2Φ)dt2+(1+2Φ)-1dr2+r22
I have determined that U0 is going to be (1+2Φ)(-1/2) by using the equation
guvUuUv=-1
However when I try to solve for U1 I get
g11*(U1)2=-1
Which is clearly not correct as this would yield
U1=(-(1+2Φ))(-1/2).
What am I doing wrong?
Apologies for formatting.
guvUuUv=-1
Do you realize that this equation contains both ##U^0## and ##U^1##? You can't get an equation for just ##U^0## from it. The notation ##g_{uv} U^u U^v## means you have to sum over all possible values for the indexes ##u## and ##v##.
This clears up the problem thank you. That slipped my mind
  • · Replies 19 ·
  • · Replies 35 ·
