Understanding Fourier Coefficients in the Fourier Transform of a Function
The discussion focuses on understanding Fourier coefficients in the context of the Fourier Transform of a function defined on the interval [0,1]. Participants clarify that Fourier coefficients are derived by integrating a function with sine or cosine functions, specifically using the equation $$c_k = \frac 1 2\int_{-\frac 1 2}^{\frac 1 2} \sum_{n=-\infty}^\infty f(x+n)e^{-i k \pi x}\,dx$$. The periodic extension of the function is emphasized, and the relationship between Fourier coefficients and the Fourier Transform is established. The importance of convergence conditions based on the bounds of the function |f(x)| is also highlighted.
  • Understanding of Fourier Transform concepts
  • Familiarity with complex analysis and integration techniques
  • Knowledge of periodic functions and their properties
  • Basic proficiency in mathematical notation and manipulation
  • Study the derivation of Fourier coefficients in detail
  • Learn about convergence criteria for Fourier series
  • Explore the properties of periodic functions and their Fourier Transforms
  • Investigate integration techniques involving complex exponentials
Mathematicians, physicists, and engineers interested in signal processing, harmonic analysis, and anyone seeking to deepen their understanding of Fourier analysis and its applications.
member 428835
Let ##f:\mathbb R \to \mathbb C## be a smooth function such that ##|f| < C/(1+|x|^2)## for some ##C##. Put ##\phi(x) = \sum_{n = -\infty}^\infty f(x+n)##. Find Fourier coefficients of ##\phi## on [0,1] in terms of the Fourier transform of ##f##.
Fourier transform ##\hat f## of ##f## is ##\hat f(k) = 1/\sqrt{2\pi}\int_\mathbb R f(x) e^{-i k x}##
Hi PF!
Unsure how to begin. Fourier transform of ##f## I've given as an equation. I'm not sure what is meant by Fourier coefficients. Fourier coefficients of what?
It seems like it is asking you to find the Fourier coefficients of ##\phi(x)##. Fourier coefficients are found by integrating the multiple of a function ##f(x)## and ##sin## or ##cos( \frac {2\pi rt}{T})## with respect to time and where ##r## is the order number of the coefficient. So ##r=4## would be the fourth harmonic.
Usually there are integration tables for different functions that help.
First, note that you don't have a formula for ##f(x)##, just an inequality that probably helps convergence. So you aren't going to do any integrations. So you have $$\phi(x) = \sum_{k=-\infty}^\infty f(x+k),~x\in [0,1]$$When you are given a function defined on ##[0,1]## and asked to find its Fourier coefficients, I guess you would assume its period is ##1## and extend it periodically. So the complex form of the Fourier coefficients would be$$
c_n =\frac 1 2\int_{-\frac 1 2}^{\frac 1 2} \sum_{k=-\infty}^\infty f(x+k)e^{-i n \pi x}~dx$$Now, I haven't worked with this stuff for years, so you should check my formulas. I am guessing that if you swap the sum and integral and make appropriate variable changes you might be able to make it look like a Fourier transform. I haven't worked it but that's what I would try. Good luck with it.
Thanks for the responses everyone, and especially this insight!
So to summarize; since we are given a function ##[0,1]##, the period must be 1. If we extend the function periodically, the complex form of the Fourier coefficients is
$$ c_k = \frac 1 2\int_{-\frac 1 2}^{\frac 1 2} \sum_{n=-\infty}^\infty f(x+n)e^{-i k \pi x}\,dx\\ = \frac 1 2 \sum_{n=-\infty}^\infty \int_{-\frac 1 2}^{\frac 1 2} f(x+n)e^{-i k \pi x}\,dx. $$
Let ##u = x + n##. Then
$$ c_k = \frac 1 2 \sum_{n=-\infty}^\infty \int_{-\frac 1 2 + n}^{\frac 1 2 + n} f(u)e^{-i k \pi (u-n)}\,du\\ = \frac 1 2 \sum_{n=-\infty}^\infty e^{i k \pi n} \hat f(k) : \hat f(k) \equiv \int_{-\frac 1 2 + n}^{\frac 1 2 + n} f(u)e^{-i k \pi u}\,du. $$
Note that ##\hat f(k)## is actually the definition of a Fourier transform of ##f(k)##. But now I'm not really sure what to do. Any ideas?
What happens if you write out a few terms of$$
\sum_{n=-\infty}^\infty \int_{-\frac 1 2 +n}^{\frac 1 2 + n}$$and combine the integrals? Starting at ##0## and working both ways.
The sum looks something like
\frac 1 2\exp\left( -2 i k \pi \right) \int_{-5/2}^{-3/2} f(u)\exp(-i k \pi u)\, du + \frac 1 2\exp\left( -i k \pi \right) \int_{-3/2}^{-1/2} f(u)\exp(-i k \pi u)\, du+\\
\frac 1 2 \int_{-1/2}^{-1/2} f(u)\exp(-i k \pi u)\, du + \frac 1 2\exp\left( i k \pi \right) \int_{1/2}^{3/2} f(u)\exp(-i k \pi u)\, du + \\\frac 1 2\exp\left( i 2 k \pi \right) \int_{3/2}^{5/2} f(u)\exp(-i k \pi u)\, du =\\
\frac 1 2 \int_{-\infty}^\infty f(u) \exp(-i k \pi u)\, du
since ##\exp(i k \pi n) = 1##.
So doesn't that pretty much solve your problem? That's a multiple of ##\hat f(k)## isn't it? Do you see why the given bound on ##|f(x)|## helps you to get convergence for ##\hat f##? And you probably better check your advanced calculus book to see whether swapping the sum and integral was legit.
Thanks a ton! Yep, everything makes good sense. I appreciate it!
  • · Replies 16 ·
