Fourier series of a step function
The discussion revolves around the possibility of creating a Fourier series expansion for a step function, particularly focusing on increasing or decreasing step functions. Participants explore the mathematical implications and methods of handling such functions in the context of Fourier analysis.
  • Exploratory, Technical explanation, Debate/contested
  • One participant inquires about the feasibility of a Fourier series expansion for a step function, seeking to understand the underlying idea.
  • Another participant states that while integrals can be written down, they will diverge for infinite step functions, but may work for finite step functions.
  • A follow-up suggests breaking the function into segments where it is constant and calculating the integral for each segment before summing them.
  • Concerns are raised about the divergence of the sum for most frequencies, questioning the validity of the approach for certain frequencies.
  • A participant expresses a desire to extract a mathematical function from a graph of voltage response, seeking guidance on how to proceed.
  • Another participant proposes representing the function as a sum of a linear or parabolic function combined with a periodic term, while expressing skepticism about the utility of this approach compared to a piecewise definition.
Participants exhibit disagreement regarding the methods and feasibility of applying Fourier series to step functions, with no consensus reached on the best approach or validity of certain methods.
Limitations include the divergence of integrals for infinite step functions and the potential complications in applying Fourier series to such functions. The discussion also highlights the need for careful consideration of function definitions and the conditions under which the Fourier series may be applicable.
chikou24i
Hello, can we make a Fourier series expansion of a (increasing or decreasing) step function ? like the one that I attached here. I just want to know the idea of that if it is possible.
You can write down the integral, but with an infinite step function like this the integrals will diverge. With a finite step function it works.
So you mean that I should take each portion appart (where f(x) is constant) and calculate the integral. Then, I add them all together ?
Is there any other method where I can calculate Fourier series normally and then I multiply them by another factor which will make them increase or decrease ?
The sum will diverge as well for most frequencies, and the approach is at best questionable for frequencies where it does not diverge.
Why do you want to Fourier transform that function?
I want to extract the mathematical function for this graph of voltage response. Could you please help me or guide me in doing that ?
https://fb-s-d-a.akamaihd.net/h-ak-xlp1/v/t1.0-0/p526x296/17457874_1911500359125961_8184758272904545979_n.jpg?oh=50117debf8fd6047caf1f0795e0a9254&oe=59500784&__gda__=1498980987_b71e34fea90ba330474f88d4a58f82d9
You could write it as sum of a linear or parabolic function and some periodic term.
I'm not sure if that is really useful, I'm quite sure a piecewise definition of the function will work better.
  • · Replies 139 ·
11K
  • · Replies 33 ·
  • · Replies 23 ·
