Fourier series of complex function
5 replies · 2K views
gl0ck
Hello guys,
I have problem with the Fourier series, since we had only one lecture about it and I cannot find anything similar to my problem in internet.
should we consider for the first f(x+1) integrated from -1 to 0 ?
http://img819.imageshack.us/img819/3508/wbve.jpg
when I use that i can find Ao= 3/2?
and about the extra info the lecturer told us if it is even it converges to 1/2 of the value, so may I consider if the series is even it converges to 1.5?
I think 2nd one is similar to the 1st one
Where did that "f(x+1)" come from? You are given that f(x)= x+ 1 for [itex]-1\le x\le 0[/itex] and f(x)= x for [itex]0< x\le 1[/itex].
gl0ck said:
Hello guys,
Say you want to calculate
$$a_n = \frac{2}{L}\int_{-L/2}^{L/2} f(x)\cos\left(\frac{2\pi n}{L} x\right)\,dx.$$ For the function you're given, L=2. Because it's piecewise continuous, you need to break up the interval of integration to correspond to each piece.
$$a_n = \int_{-1}^{1} f(x)\cos(2\pi n x)\,dx = \int_{-1}^0 f(x)\cos(2\pi n x)\,dx + \int_0^1 f(x)\cos(2\pi n x)\,dx.$$ In the first integral on the righthand side, ##x## is between -1 and 0, so in that integral, you replace f(x) by ##x+1##. In the second integral, ##x## is between 0 and 1, so you replace f(x) by 1. You need to understand this part because what you wrote down was gibberish.
You now have
$$a_n = \int_{-1}^0 (x+1)\cos(2\pi n x)\,dx + \int_0^1 \cos(2\pi n x)\,dx,$$ which is left for you to evaluate. You calculate ##b_n## similarly.
Hey guys, I've made some progress, I think I've solved the problems
http://imageshack.us/a/img59/9217/s0du.jpg
For the 1st question I got for An and Bn these things:
http://imageshack.us/a/img543/6600/6kl1.jpg
and the final answer should be multiplied by 1/2 and 3/2 ( Ao ) which forgot to include.
http://imageshack.us/a/img689/6442/f6yz.png
2nd question I got only cosine terms since the function is even with period 2pi
so for An I got this : http://imageshack.us/a/img35/7937/06ha.jpg
and for the final answer when I subsitute the d^2y/dx^2 with [itex]\sum-Cnn^2cos(nx)[/itex]
and y with [itex]\sum-Cncos(nx)[/itex] to be equal to An
and got this:
http://imageshack.us/a/img5/4756/89rb.jpg
Hope I am right and thanks
I know that using images may be convenient for you, but it's annoying for the helpers. Perhaps someone else will be kind enough to go to the trouble of opening up each image to check your work.
I thought it pops up in the whole threat just like the formulas used in the forum , or it just happens to me? Don't know what you mean
