How Does Time Affect the Displacement of a Plucked Violin String?
The discussion focuses on the displacement of a plucked violin string modeled using Fourier Series. The initial displacement is defined as a triangular function, and the solution takes the form y(x,t) = Σ a_n sin(nπx/L) cos(nπvt/L). The key point of confusion is the placement of vt within the cosine term rather than the sine term, which is clarified by understanding the separation of variables in wave equations. The wave speed v is calculated using the formula v = pT/µ, where p is the linear density and T is the tension in the string.
  • Understanding of Fourier Series and their application in wave equations
  • Knowledge of wave speed calculation using v = pT/µ
  • Familiarity with the concept of normal modes in vibrating strings
  • Basic principles of harmonic motion and trigonometric functions
  • Study the derivation of Fourier Series for different boundary conditions
  • Learn about the physical interpretation of wave functions in vibrating strings
  • Explore the concept of normal modes and their significance in string instruments
  • Investigate the effects of tension and linear density on wave speed in strings
Students and educators in physics, particularly those studying wave mechanics and string instruments, as well as musicians interested in the mathematical modeling of sound production.
danmel413
A violin string is plucked to the shape of a triangle with initial displacement:
y(x,0) = { 0.04x if 0 < x < L/4
(0.04/3)(L-x) if L/4 < x < L
Find the displacement of the string at later times. Plot your result up to the n = 10 term, for t = L/10v, L/5v, and L/2v, where v = p T /µ is the speed of the wave. Are all harmonics excited?
The normal Fourier Series equations (the ones I use are here)
The solution is supposed to be of the form y(x,t) = Σansin(nπx/L)cos(nπvt/L)
My only issue is conceptually. I understand how to go through the math to get an. Why is it that the vt is within the cosine and not the sine? How am I even supposed to know to add the vt in? I feel like this is something unbelievably basic that I'm missing.
Why would you think it should be a sine? The string is released from rest. How would you solve the problem?
Notice first that the solutions terms are a product of sin(function of x only) and cos(function of t only). What do you think these two "separated" pieces represent, conceptually?
  • · Replies 26 ·
13K
