Understanding Fourier Transform: Solving a Homework Problem Step by Step
This discussion focuses on solving a Fourier Transform problem, specifically evaluating the integral \( F(b) = \int_0^{\pi} \sin(t) e^{bt} \, dt \) using integration by parts. Participants highlight mistakes in the original solution, including incorrect limits of integration and errors in the exponential expressions. The importance of clear mathematical notation is emphasized, with recommendations to use LaTeX for better readability. The final result should not contain extraneous terms, such as an extra \( \omega \) in front of \( \sin(\omega \pi) \).
  • Understanding of Fourier Transforms
  • Proficiency in integration techniques, specifically integration by parts
  • Familiarity with complex exponentials and their properties
  • Basic knowledge of LaTeX for typesetting mathematical expressions
  • Learn how to apply integration by parts in Fourier Transform problems
  • Study the properties of complex exponentials in Fourier analysis
  • Practice typesetting mathematical equations using LaTeX
  • Review common mistakes in solving integrals involving trigonometric functions
Students studying signal processing, mathematicians working with Fourier analysis, and educators teaching calculus and differential equations.
Aows
Hello everyone,
am trying to solve this Fourier Trans. problem,
here is the original solution >> https://i.imgur.com/eJJ5FLF.pngQ/ How did he come up with this result and where is my mistake?
All equation are in the above attached picture
here is my attempt,
part 1>> https://i.imgur.com/DT2tJ0y.jpg
part 2>> https://i.imgur.com/jopEoQd.jpg
part 3>> https://i.imgur.com/cKXoekT.jpg
Likes berkeman
Aows said:
Hello everyone,
here is my attempt,
The answer obtained in the "original solution" you posted happens to be correct, despite several blunders the author made along the way (for example, there is no ##\theta## in the exponential expression for ##\sin(t)##, and the limits on the indefinite integration are ##|_0^{\pi}##, not the ##|_{\pi}^0## written by the author). I could follow your work until the middle of part 2, then it got too messy and I gave up. Please try to follow PF standards and type out your work, or else at least write it out clearly and neatly before photographing it. Your final result has an extra ##\omega## in front of the ##\sin (\omega \pi)##.
BTW: many helpers will not look at posted images (rather than typed work); usually I will not look at them either, but today I made an exception, and then had to give up part way through.
Likes Aows
In part 2, going from line 3 to line 4, you forget to distribute accordingly: e^{j\pi(1-\omega)}=e^{j\pi}e^{-j\pi\omega} Instead, you distribute as if the negative sign is not there.
Likes Aows
thanks indeed,
is this the only mistake ?
thanks a lot for your advices and comment, can you spot more mistake if any available ? that would help me a lot.
I stated already that I would not attempt to read what you did past the middle of part 2, because it is too messy.
You are doing it the hard way. It is much easier to evaluate ##F(b) = \int_0^{\pi} \sin(t) e^{bt} \, dt## using integration by parts (twice)---anyway, a standard calculus 101 homework problem---simplifying as much as possible. THEN put ##b = -j \omega.##
Likes Aows
Ray Vickson said:
I stated already that I would not attempt to read what you did past the middle of part 2, because it is too messy.You are doing it the hard way. It is much easier to evaluate ##F(b) = \int_0^{\pi} \sin(t) e^{bt} \, dt## using integration by parts (twice)---anyway, a standard calculus 101 homework problem---simplifying as much as possible. THEN put ##b = -j \omega.##
it is necessary to solve it like this but i don't think it is messy (dont pay attention to the RHS of the paper) the solution is on the LHS.
Aows said:
Hello Dr. Ray and Daniel,
I've made some corrections which made my solutions very close to the original solution but still some mistake, can you identify them ??
here is my attempt:
https://i.imgur.com/jkVdK7z.jpg
and here is the original solution:
You should really write your math out in your post instead of attaching a file. There are tutorials for typesetting math using LaTeX commands on the site (highly recommend). Additionally, people on the forum will likely get tired of pointing out individual mistakes to you. Nevertheless, from line 2 to 3 on the document where you provide your most recent attempt, you pull the (-1)s out, but not the -1s beside the exponentials. If you factor out the minus signs correctly, the -1s will turn into +1s. Carry it forward, and you'll get the correct answer.
Likes Aows
Mr. Daniel where is the mistake in my pulling the (-1), kindly, can you explain more ? that would help me a lot?
