Free Body Diagrams: Static Equilibrium
To determine the force F needed to keep blocks A and B in static equilibrium, the equations for horizontal and vertical forces must be analyzed, specifically where Fx=0 and Fy=0. The participant calculated Fx as Fcos20 and Fy as Fsin20 - 5 kg, but needed clarification on how to find acceleration (a). It was explained that the acceleration can be derived using the relationship between the weight of the blocks and the applied force components. Ultimately, the calculated force F was found to be 283 N, based on the correct application of the given angle and mass. The discussion emphasizes the importance of accurately applying static equilibrium principles in physics problems.
hunter007
Blocks A & B each have mass 5kg, and all contact surfaces are frictionless.
Determine the force F needed to keep the blocks in static equilibrium, and the forces on all contact surfaces.
I know I need to find where Fx= 0 and where Fy= 0.
Fx = Fcos20
Fy= Fsin20 - 5 kg
Am I even close?
Hi hunter007, welcome to PF.
When you apply force F to the systemis, the acceleration of the system is
a = F/(Ma + Mb)...(1). It is parallel to the ground.
Since block A is not attached to the block B, due the inertia, it will experience an equal and opposite acceleration. The block A will remain rest when component of the weight of the block A balances the component of the acceleration.
Equate these components and find a. Put this value in equation(1) to get F.
Could you explain a little more on how to get a? Once I find that I could find F.
mg*sinθ = a*cosθ.
Find a.
a = 5(9.8)*tan(30)
= 28.3
F= 28.3(5+5) = 283 N.
Did I do it right?
The given angle is 20 degrees.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
