Free fall acceleration of a bolt
14 replies · 7K views
suxatphysix
A bolt is dropped from a bridge under construction, falling 98 m to the valley below the bridge.
(a) In how much time does it pass through the last 30% of its fall?
(b) What is its speed when it begins that last 30% of its fall?
(c) What is its speed when it reaches the valley beneath the bridge?
Tried splitting the problem into 2 parts by multiplying 98 x .3 to solve for the final velocity for the first 70% of the fall, then using that velocity as the initial velocity for the 30% of the fall and the other 30%(29.4m) of the trip.
[tex]\Delta[/tex]t=-vi +/- [tex]\sqrt{vi^{2}+2ay}[/tex] / a
That's a good approach. What answers did you get?
got 8.20 for part a seconds but it was wrong. so i stopped at part a
Can you show what you did to get that?
vf[tex]^{2}[/tex]=0 + 2(-9.8m/s^2)(-68.6m)
vf= 36.69m/s
[tex]\Delta[/tex]t = -36.69m/s +/-[tex]\sqrt{36.69m/s^2 + 2(-9.8m/s^2)(-29.4) }[/tex] /-9.81
=8.20s
vf= 36.69m/s
=8.20s
Everything looks right except, your denominator in your quadratic solution... I think it should be 9.81, not -9.81... so you'll chose the positive numerator instead of the negative one...
why 9.81 when gravity is always negative?that means the time would actually be 0.723? i don't know if that sounds logical
Can you write out the quadratic equation you had?
Ah... I think I see now.
vf=0 + 2(-9.8m/s^2)(-68.6m)
vf= 36.69m/s
Here you should have taken vf as -36.69m/s, not +36.69m/s. ie the negative square root is what you want.
Yes, that equation is correct.
omg it was right! thanks!
now to try and answer part b and c.
cool! another way to solve that problem that I just saw... you can get the total time of the drop. and subtract the time of the first 70%
So solving (1/2)gt^2 = 98, gives t = 4.4699s. And the solve the time for the first 70%. (1/2)gt^2 = 0.7*98, gives t = 3.7397s, so the difference is the time you need 0.730s.
i got both b and c.
b - 36.69
c - 43.85
thanks learningphysics for getting me started on that problem.
Much appreciation.
suxatphysix said:
i got both b and c.
b - 36.69
c - 43.85
Much appreciation.
cool! no prob. good job!
