Free Fall: Does an Object Reach Speed of Light?
  • Context: Graduate
  • Thread starter Thread starter aaron35510
    Fall Free fall
In free fall, an object experiences only gravitational force, with Earth's gravitational acceleration at 9.81 m/s². However, according to Einstein's theory of relativity, no object with mass can reach the speed of light (c). As an object's speed approaches c, its relativistic mass increases, causing acceleration to diminish. This phenomenon is evident in particle accelerators, where particles near light speed exhibit increased mass and reduced acceleration, confirming that c is an unattainable limit for massive objects.
  • Understanding of Einstein's theory of relativity
  • Basic knowledge of gravitational acceleration (9.81 m/s²)
  • Familiarity with relativistic mass and its implications
  • Concept of escape velocity in Newtonian mechanics
  • Study Einstein's theory of relativity and its implications on mass and speed
  • Learn about relativistic effects in particle accelerators
  • Research gravitational effects near black holes and their influence on speed measurements
  • Explore the properties of massless particles, such as neutrinos, and their behavior in relativistic contexts
Physicists, students of physics, and anyone interested in the principles of relativity and gravitational effects on motion.
aaron35510
In free fall, there is no air resistance, so the only force acting upon the object of free fall would only be its weight.
Now the question is, if an object keeps accelerating due to free fall, wouldn't it eventually reach the speed of light? For example, Earth's g=9.81 m/s^2, so over a course of time, it would eventually accelerate to the speed of light (considering the fact that the object would never hit the ground.)
So since Einstein proclaimed that NOTHING that has mass can travel at the speed of light, wouldn't this prove him wrong?
The same situation exists in a particle accelerator. As the speed increases, the mass increases (and has been measured for particles near the speed of light). As the speed approaches the speed of light, it gets very large indeed and so the acceleration approaches zero. There are some other problems with accelerators - notably EM radiation draining away the kinetic energy - but it certainly appears that c cannot be reached.
yes. the short answer is that intuition simply breaks down for particles traveling near speed of light, and the acceleration is not constant 9.8 anymore. You have to use different equations that correct for relativistic effects.
g=9.81 is only valid near Earth's surface. It varies with distance. Even in Newtonian mechanics nothing falling towards the Earth could reach more than the Earth's escape velocity, which is not even close to the speed of light.
Yes. And if apples where flying up from the ground to the tree it would prove Newton wrong. But neither one was observed so far.
What about the case of a neutron falling into a black hole? Wouldn't the increase in mass also correspond to an increase in gravity, so maintaining or increasing the rate of acceleration? Or the case of a positron and electron collision?
Increase in mass also corresponds to an increase in inertia. Even in Newtonian mechanics the mass of a body is irrelevant for its acceleration by gravity.
There really are better ways to accelerate stuff than by gravity, but nothing will accelerate stuff beyond the speed of light.
speed is ill-defined unless you specify what the observer is. If the observer is falling in the block hole with the particle, he/she would not measure anything greater than c. For anyone outside the horizon, you simple can't measure the speed (i.e. there is no well defined speed).
so in this case, how do you calculate the relativistic acceleration of a free falling object?
Plus, aren't neutrinos mass-less particles anyway?
  • · Replies 16 ·
  • · Replies 31 ·
