fisher garry
- 63
- 1
$$\textbf{F} \cdot d\textbf{l}=q(\textbf{E}+\textbf{v} \times \textbf{B})\cdot \textbf{v} dt$$
If we denote $$q=\rho d \tau$$ and $$\rho \textbf{v}=\textbf{J}$$
$$\frac{dW}{dt}=\int_{V} (\textbf{E} \cdot \textbf{J}) d \tau.$$
From maxwell law's
$$\textbf{E} \cdot \textbf{J}=\frac{1}{\mu _0} \textbf{E} \cdot (\nabla \times \textbf{B}) - \epsilon _0 \textbf{E} \cdot \frac{\partial \textbf{E}}{\partial t}
we use the product rule:
$$\nabla \dot \cdot (\textbf{E} \times \textbf{B})=\textbf{B} \cdot (\nabla \times \textbf{E})-\textbf{E} \cdot (\nabla \times \textbf{B}).$$
Faraday's law:
$$\nabla \times \textbf{E}=-\frac{\partial \textbf{B}}{\partial t}
gives
$$\textbf{E} \cdot (\nabla \times \textbf{B})=-\frac{\partial \textbf{B}}{\partial t} - \nabla \cdot (\textbf{E} \times \textbf{B})
$$\textbf{B} \cdot \frac{\partial \textbf{B}}{\partial t}=\frac{1}{2} \frac{\partial}{\partial t}(B^2)$$
$$\textbf{E} \cdot \frac{\partial \textbf{E}}{\partial t}=\frac{1}{2} \frac{\partial}{\partial t}(B^2)$$
$$\textbf{E} \cdot \textbf{J}=\frac{1}{2} \frac{\partial}{\partial t}(\epsilon_0 E^2+\frac{1}{\mu_0} B^2) - \frac{1}{\mu_0} \nabla \cdot (\textbf{E} \times \textbf{B}).$$
The theory above is taken from Griffiths introduction to electrodynamics.
From there by rearranging:
$$\textbf{F} \cdot d \textbf{l}=\frac{q}{\rho}[-\frac{1}{2} \frac{\partial}{\partial t}(\epsilon_0 E^2+\frac{1}{\mu_0} B^2) - \frac{1}{\mu_0} \nabla \cdot (\textbf{E} \times \textbf{B})] dt$$
From a quantification perspective we could rewrite the last part to:
$$\textbf{F} \cdot d \textbf{l}=\frac{q}{\rho}[-\frac{1}{2} \frac{\partial}{\partial t}(\epsilon_0 E^2+\frac{1}{\mu_0} B^2) - \frac{1}{\mu_0}c \nabla \cdot ( \textbf{B}^2) ] dt$$$$\frac{d W}{d t}=\frac{q}{\rho}[-\frac{1}{2} \frac{\partial}{\partial t}\int_{V}(\epsilon_0 E^2+\frac{1}{\mu_0} B^2) d \tau - \frac{1}{\mu_0}\int_{V}c \nabla \cdot ( \textbf{B}^2) \textbf{i}] d\tau$$
The first term is recognized as the energy density. If all the energy is sent out instead of stored in the system:
$$\frac{d W}{d t}= \frac{1}{\mu_0}\int_{V}c \nabla \cdot ( \textbf{B}^2) \textbf{i}] d\tau$$
From the divergence theorem:
$$\frac{d W}{d t}= \frac{c}{\mu_0}\int_{A} \textbf{B}^2 \cdot dA=\frac{c}{\mu_0} \textbf{B}^2 4 \pi r^2 $$
If we denote this emitted energy as Em waves:
$$B=\textbf{B} \sin [2 \pi ft]$$
$$W=\frac{c}{\mu_0} \textbf{B}^2 \int_{0}^{T} \sin^2[2 \pi ft] 4 \pi r^2 dt$$
$$\sin^2x=\frac{1}{2}-\cos(2x)$$
$$W=\frac{c}{\mu_0} \textbf{B}^2 \int_{0}^{T}(\frac{1}{2}-\cos([4 \pi ft]) 4 \pi r^2 )dt=\frac{c}{\mu_0}\textbf{B}^2 \frac{1}{2} T 4 \pi r^2$$
From another approach of the theory in Griffiths:
Again we look at the energy sent out and assume that no energy is stored
Now instead of using the divergence theorem there could perhaps be possible to do this volume integral above and then equate it to:
$$\frac{c}{\mu_0}\textbf{B}^2 \frac{1}{2} T 4 \pi r^2$$
And then solve for $$T=\frac{1}{f}$$
What I have done so far:
We assume that B goes radially outwards and use spherical coordinates to solve the divergence theorem:
The divergence in spherical coordinates:
$$\frac{1}{r^2} \frac{\partial r^2 A_r}{\partial r} + \frac{1}{r sin \theta}\frac{\partial}{\partial \theta}A_{\theta}sin_{\theta} + \frac{1}{r sin \theta} \frac{\partial A_{\varphi}}{ \partial \varphi}$$
Since we only have radial divergence we can obtain:
$$\frac{d W}{d t}= \frac{1}{\mu_0}\int_{V}c \nabla \cdot ( \textbf{B}^2) \textbf{i}] d\tau=\frac{c}{\mu_0}\int_{V} \frac{1}{r^2} \frac{d}{dr}(r^2B^2)4 \pi r^2 dr=\frac{4 \pi c}{\mu_0}\int_{0}^r d (r^2B^2)=\frac{4 \pi c}{\mu_0} (r^2B^2)$$
Which we see is the same result as we ended up with above as:
$$W=\frac{c}{\mu_0}\textbf{B}^2 \frac{1}{2} T 4 \pi r^2$$
But what if we instead tried to integrate
$$\frac{c}{\mu_0}\int_{V} \frac{1}{r^2} \frac{d}{dr}(r^2B^2)4 \pi r^2 dr$$
by rewriting:
$$B=\textbf{B} \sin [2 \pi ft]=\textbf{B} \sin [2 \pi f\frac{r}{c}]$$
Thus
$$\frac{c}{\mu_0}\int_{V} \frac{1}{r^2} \frac{d}{dr}(r^2\textbf{B}^2 \sin^2 [2 \pi f\frac{r}{c}])4 \pi r^2 dr$$
Then we have a r dependency for the integral. I have tried and I ended up with a longer expression. The better news was that if I equated it with
I ended up with an equation that only had R and f as variables since B is the same for the two divergence theorems versions from the derivations above. I guess I could initially determine R from a setup point of view. But unfortunately it did not give any solutions. It seems that since there are 2 Work equations. Equating thoose two could give a solution of frequency. But I have not found a solution that makes sense. Anyone that wants to try to find a solution for the frequency with this setup?
Here is my attempt attached just in case anyone want to take a look (the answer gave me 0 answers as far as I could tell):
From maxwell law's
Faraday's law:
gives
by rewriting:
Thus
