Frequency of light to eject electrons from gold
To eject electrons from a gold surface with a maximum kinetic energy of 6.48×10(−19) J, the frequency of light must be calculated based on the work function of gold, which is 4.58 eV. The energy of a photon is related to its frequency, and the total energy required is the sum of the work function and the kinetic energy. Converting the work function from eV to joules is necessary for accurate calculations. The correct approach involves using the formula for maximum kinetic energy to solve for frequency. The discussion highlights the importance of understanding energy conversions in photon interactions with metals.
mhooker_10
What frequency of light must be used to eject electrons from a gold surface with a maximum kinetic energy of 6.48×10(−19)J ?
The work function of gold is 4.58 eV.
f=
You have to at least attempt an answer to a homework question.
Whats the energy of a photon, in terms of frequency?
I used the formula for K(max) and solved for f and got 6.91 x 10(33)...and that not the right answer
So you need to supply enough energy to overcomethe work function and then supply the KE.
So convert the work function into joules and add to the ke.
Then you just need the energy of aphoton in terms of frequency.
oops - you didn't post in the HW forum, so didn't get the list of things to do.
Nevermind...I figured it out
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
