Fresnel lens project with my dad
  • Context: High School
  • Thread starter Thread starter MACHO-WIMP
    Fresnel Lens Project
The discussion revolves around the functionality of a Fresnel lens salvaged from an old TV, particularly focusing on how a crack in the lens affects its ability to concentrate sunlight for applications like burning leaves. Participants explore the lens's intended use, its optical properties, and the impact of seasonal conditions on its performance.
  • One participant questions the impact of a crack on the lens's functionality, suggesting it should not significantly affect performance.
  • Another participant argues that the lens was not designed to focus light to a point, indicating it may not be effective for burning leaves.
  • Some participants clarify that no lens can focus sunlight into a true point due to the sun being a non-point source, and instead, it can only focus light onto a small area.
  • There is a discussion about the specific type of lens used in TVs, with some suggesting it is meant to diffuse light rather than concentrate it.
  • One participant speculates on the focal length of the lens, estimating it to be around 0.5m, and discusses its potential use in rear-projection TVs.
  • Concerns are raised about safety regarding the use of gasoline in experiments, with a warning against dangerous practices.
Participants express differing views on the lens's functionality and intended use, with no consensus reached regarding its effectiveness for concentrating sunlight or the implications of the crack.
Some assumptions about the lens's design and intended application remain unresolved, and there is uncertainty regarding the specific optical characteristics of the lens in question.
Individuals interested in optics, DIY projects involving lenses, or those exploring the practical applications of salvaged materials may find this discussion relevant.
MACHO-WIMP
Hello,
So my dad and I took apart our old TV that had a Fresnel lens inside. Unfortunately there is a crack near the edge due to a billiard ball accidentally being dropped on it. I was wondering how much this crack would affect the lens' ability to focus the sunlight into a point. When we tested this, it didn't work as well as it did in the video, and had trouble burning dead leaves but we think that since it is winter here in the Northern Hemisphere that might have something to do with it. Any comments or advice would be very helpful. Thanks!
PS: we were inspired by this video:
Science news on Phys.org
Just one crack should not have much effect at all on the lens's functionality.
Your description suggests that this lens was not designed to focus light to a point, so it would not be that good at burning leaves. Still, summer noonday sun should improve the performance somewhat.
Also, no lens has the ability "to focus the sunlight into a point", mainly because the sun is not a point source to begin with. The best you can do is focus the sun onto a small area, as determined by the focal length of the lens.
Alright thanks you guys! Helped a lot.
A fresnel lens from a TV/Monitor is used to diffuse light ( spread it out) NOT concentrate light
Dave
Dave
Where would you find a fresnel lens in a TV? They are common enough in old fashioned OHPs but, as for a TV - are we talking about the lens they used to put in front of 9" tubes to make them look line 12" tubes? That would be a convex (Magnifying) lens, which should focus the Sun OK. It would probably have a focal length of 0.5m (<=2 dioptres) or so, I'd imagine. It couldn't be much shorter than that or the field of view would be too small for more than one person to watch TV.
(Apologies for trying to tell my astronomer grandma how to suck optical eggs!)
Found it!
I've never seen the insides of one of these:
https://www.youtube.com/watch?v=348PUYaoGm8
At the end of the video, you see him also pull out a fairly large mirror.
I'm guessing that there is some kind of miniature TV inside that the mirror and fresnel lens focus on.
More here if you are interested: Rear-projection television
In regards to the OP's video, what he did with that gasoline was incredibly stupid. Do not try anything like that, or you may end up without a recognizable face.
There's one inside every TV/ monitor that uses backlighting ... so normally LCD type
it sits behind the LCD panel and it diffuses the light from the back lights to give an even lighting across the whole screen
the backlight is usually either fluoro tubes or LEDs
don't think they are used in Plasma screens ... never pulled one apart to find out
thanks Om
yes they were also used in the rear projection TVs as your video showed
I forgot about those ones and was mainly thinking of the other use
cheers
Dave
Ah yes; my memory deliberately edited out the rear projection generation TVs (they were so ghastly). I'm not sure about the optics but it could be a way to achieve a long focal length and big aperture in a short space (a la telephoto lens).
In the YouTube movie, the lens seems to be a little under 1 Diopter and the focussing is not too fussy. He is working in full, bright sunlight, of course.
In the LCD backlight system, I always thought it was just a lenticular screen but I didn't think about it in depth. The backlight was a number of strip lights so any lens would be cylindrical.
  • · Replies 19 ·
11K
  • · Replies 110 ·
25K
