Can ##a_1## and ##a_2## be zero in the Frobenius' method solution for this DE?
  • Thread starter Thread starter BearY
    Frobenius Method
The discussion centers on using Frobenius' method to solve the differential equation 5x²y'' + xy' + (x³ - 1)y = 0. The participants analyze the power series solution and derive conditions for the coefficients a_0, a_1, and a_2 based on the roots r of the characteristic equation. It is established that if a_0 is non-zero, then r must equal either 1 or -1/5, leading to a_1 and a_2 being zero. The conversation emphasizes that the values of a_1 and a_2 being zero are necessary for the solution's validity, and any non-zero coefficients for higher terms can be expressed in terms of a_0. The conclusion is that the constraints on a_1 and a_2 are crucial for finding valid solutions to the differential equation.
BearY
Use Forbenius' method to solve this DE:
$$ 5x^2y''+xy'+(x^3-1)y=0$$
Seek power series solution in the form ##y=\sum _{n=0}^{\infty } a_n x^{n+r}##, ##a_0\neq0##
Sub in the ansatz y, get $$ \sum _{n=0}^{\infty }a_n[5(n+r)(n+r+1)+n+r-1]x^n + \sum _{n=0}^{\infty }a_nx^{n+r+3} = 0 $$
Align the powers of x, split first sum to combine with second sum:$$ \sum _{n=0}^{\infty }\{a_{n+3}[5(n+r+3)(n+r+2)+n+r+3-1]+a_n\}x^{n+3} + a_0[5r(r-1)+r-1]+a_1[r(r+1)r+r]x+a_2[5(r+2)(r+1)+r+1]x^2=0$$
This is where I get stuck, I am not sure about how to handle ##a_1## and ##a_2## term or how to find solutions of ##r## with them being there. I can't find out if ##a_1## and ##a_2## can be zero or not, whether or why it matters.
Thanks in advance.
Thanks in advance.
I have not checked your work, but assuming it is correct we can say:
(1) either ##a_0=0## or ##5r(r-1)+r-1 = 0## (or both).
(2) either ##a_1=0## or ##r^2(r+1)+r = 0## (or both).
(3) either ##a_2 = 0## or ##5(r+1)(r+2)+ r+1=0## (or both).
From (1): if ##a_0 \neq 0## then ##(5r+1)(r-1) = 0##, so either ##r = 1## or ##r = -1/5##. Thus, if ##r = 1## or ##r = -1/5## then ##a_0## is arbitrary and ##a_1 = a_2 = 0##. If ##r \neq 1, -1/5## then ##a_0 = 0##.
Look at the other cases in a similar way. That will give you a candidate list of possible ##r## values and corresponding cases for ##a_0,a_1,a_2 .## Then you need to figure out how to eliminate some of those possibilities.
Note added in edit: I guess we can eliminate the case ##a_0 = 0##, because ##a_0 x^r## is the lowest-power term in ##y##, so cannot have a zero coefficient. In other words, we do have ##a_0 \neq 0##, so we can say for sure that either ##r = 1## or ##r = -1/5##, and also that ##a_1 = a_2 = 0## (assuming your work was correct).
Likes BearY
Two polynomials ##p(x) = \sum a_nx^n\, , \,q(x)= \sum b_nx^n## are equal if all ##a_n=b_n## and if ##q(x)=0## then all ##b_n=0##. Now which coefficients at position ##0 , 1, 2 ## are left on the left hand side? Don't forget, that ##a_0 \neq 0## if you solve for ##r##. And do you know something about ##r##, e.g. ##r > 0## or can it be arbitrary?
Likes BearY
That is to say since ##a_0## term must be 0, ##a_0 \neq 0##, r can only be the solutions to ##a_0## term equal to zero. If the other two coefficients happen to be arbitrary constants that don't have to be 0, they can be included in the coefficients of the general solution of the DE, right?
I beg your pardon, I am not sure what does being left on the left hand side mean. r is arbitary constant.
I have no idea what you are attempting to say; it makes no sense to me. Re-read my post---especially the part added in edit.
Likes BearY
You have an equation ##\text{ (LHS =) } p(x) = p_0 +p_1x + p_2x^2 + \ldots = 0 = 0\cdot 1 + 0 \cdot x + 0\cdot x^2 + \ldots \text{ (= RHS) }##. Now compare the positions at ##x^n \, : \, p_0=0 \; , \; p_1=0\; , \; p_2=0\; \ldots \;p_n=0##. I wrote ##p_i## because those new coefficients are themselves polynomial expressions in the ##a_j##, e.g. ##p_0 = a_0 (5r^2-4r-1)##. This can be solved and you get two possible values for ##r##. Take them and continue with ##p_1 = a_1 \left( (1+r)\cdot (1+5r)-1 \right)## and so on.
Likes BearY
I am sorry, I meant to ask, in this question we can indeed be sure that ##a_1 = a_2 = 0##. But what happens if a solution to ##r## allows other coefficients to be non-zero? Or is that impossible?
Re-read post #3 which explains the comparison of two polynomials.
You cannot rule it out. All you know is ##a_0 \neq 0##. E.g. I got ##a_3 = -\dfrac{1}{63} a_0## in one case, which is thus unequal to zero, too.
Likes BearY
I understand it now. Thank you
I think ##a_3## will be the result of the recurrence relationship given by the sum in the last step I wrote in #1. And so will be ##a_6## and so on. The value of ##r## only makes ##a_1 = a_2 = 0## right?
In the case ##r=1## I had ##a_1=a_2=0## as well. I think this is also true for the other value of ##r##, but I haven't checked.
Likes BearY
We need ##a_1 = a_2 = 0##. Then we can get ##a_3## in terms of ##a_0##, can get ##a_4## in terms of ##a_1##---so is 0, etc. Altogether, the only nonzero values of ##a_n## for ##n >0## are ##a_3, a_6, a_9, \ldots ,## and in principle you can get them all in terms of ##a_0.##
Likes BearY
I am sorry for the vagueness, I meant other as ##a_1## and ##a_2##, I don't know why I said other instead of that, doesn't save much typing anyway. I am just wondering what if for ##a_0f(r)## and ## a_1g(r)##, the solution to ##f(r) = 0## and ##g(r) = 0## are the same. Or is it impossible?
Obviously, if ##a_0 \neq 0## the solution of ##a_0 f(r) = 0## is the same as that of ##f(r) = 0##. But if ##a_0 = 0## the equation ##a_0 f(r) = 0## contains no useful information about ##r##.
So: go back are re-read past posts: we DO have ##a_0 \neq 0## (essentially by definition). That tells us enough about ##r## that we can say with absolute, 100% certainty, that ##g(r) \neq 0##, FORCING ##a_1 = 0##. End of story.
Likes BearY
