From Celsius to Kelvin - why +273?
  • Context: High School
  • Thread starter Thread starter klng
    celsius Kelvin
The conversion from Celsius to Kelvin involves an offset of 273.15, which aligns the Celsius scale with absolute zero, the starting point of the Kelvin scale. The Celsius scale is defined with 0 degrees at the freezing point of water and 100 degrees at the boiling point, while the Kelvin scale begins at absolute zero, which is -273.15 degrees Celsius. This relationship is crucial for scientific calculations, particularly in thermodynamics, where absolute temperature is necessary. Understanding this conversion is essential for educators and students in physics and chemistry.
  • Understanding of temperature scales: Celsius and Kelvin
  • Basic knowledge of thermodynamics
  • Familiarity with the concept of absolute zero
  • Knowledge of scientific measurement standards
  • Research the significance of absolute zero in thermodynamics
  • Explore the differences between Celsius, Kelvin, and Fahrenheit scales
  • Learn about the implications of temperature scales in gas laws
  • Investigate the historical development of temperature measurement standards
Educators, students in physics and chemistry, and anyone interested in the principles of temperature measurement and conversion.
klng
Hi,
I am puzzled by the use of the number 273 when converting from Celsius to Kelvin and vice versa.
I know that Celsius scale is based on ice point and steam point, whereas Kelvin scale is based on triple point of water, which is very very close to ice point.
I am a teacher and i was asked the above question by a student. My first gut impulse is that we assign numbers as a form of starting point for comparison. It is like asking why pi is 3.14.
But just to set my mind at ease, are there further deeper reasons how this number 273 is chosen?
Thanks all in advance.
Science news on Phys.org
The zero on the Celsius scale is rather arbitrary. What makes the freezing point of water at standard pressure so special?
The zero on the Kelvin scale is anything but arbitrary. Absolute zero is a very special temperature. The reason for the 273.15 offset that is what is needed to make a temperature whose zero point is absolute zero have the same scale as the Celsius scale.
Hello
Centigrade scale has ice point (melting ice at 1 atm) and steam point (steam at 1 atm) taken for the scale, 0 degree celsius and 100 degree celsius respectively.
For Kelvin scale, its just that the scale starts from absolute zero ( the coldest temperature ). If absolute zero is in centigrade scale then its -273 degree celsius.
As for the pi question, I think that it is a constant for something to be true... let's say you know the area of a circle which is 78.6cm^2 with radius 5cm. To get 50cm^2 you need to multiply radius with radius and an unknown, which is pi.
Please correct me if I am wrong thanks!
You've got to be careful as the Pi analogy is confusing.
Pi is not just a number assigned as a starting point, the value is something special (the name is arbtrary, but the value isnt) very much like absolute zero which the Kelvin scale is based off. So Pi is very special number that is infinitely long, and the only reason why we comonly use the approximation of 3.14 is because it strikes a balance betweeen ease of calculation and accuracy.
Scales that compare one thing to another such as farenhheit and celsius are correct to be compared to something that is a starting point to make things easier.
Just nit picking mate, but its area not vol. :P
oops i will correct it:blushing:
To clarify this a bit. Celsius scale was define to be 0 degrees at the freezing point of water (at 1 atm pressure), and 100 degrees at the boiling point of water (at 1 atm pressure). I doubt that at the time of this definition anyone knew what the limit for how cold things can get was. This was detemined later on the Celsius scale, it turned out to be -273.15.
Pi is a transcendental number.
http://en.wikipedia.org/wiki/Transcendental_number
However it's definition as the ratio circumference / diameter of a circle is exact. If pi is used as a unit of magnitude, then the issue is eliminated.
Maybe this would help but I doubt it - make the analogy to star brightness. A 0 magnitude star is standardized and anything dimmer goes up in value. However, brighter objects like the sun have a magnitude in the negatives! Then you can even go on to make the comparison to absolute magnitudes being like the kelvin scale. I guess the problem is, if you get deeper into the argument, there is no "absolute 0" for brightness (although you kinda have the inverse where you could have... "absolute infinity" being a point in the sky that has 0 light intensity... thus is just space, but that's kinda silly and non-technical).
I'm trying to think of a good analogy but I'll be damned if I can...
Also you can't use Celsius for the gas laws that divide by a temperature, because you can't divide by zero. So you must use kelvin.
This thread is more than 2 years old.
  • · Replies 37 ·
9K
13K
