Function of PD, PI, ID and PID microcontrollers on a system
  • Thread starter Thread starter Sam Groves
    Pd System
Different microcontrollers, such as P, I, D, and PID, interact with systems in unique ways, affecting error and final values differently. The combination of these controllers yields results that depend on specific constants K0, K1, and K2, indicating that their interaction is more complex than a simple RGB analogy. Feedback compensation must be tailored to each system for optimal performance, as the effectiveness of PID controllers can vary based on the user's understanding of the system dynamics. While PID is commonly taught and used in industrial settings, many practitioners lack a deep theoretical understanding, which can lead to practical limitations. The derivative term (D) is often unnecessary and can complicate control unless its application is well understood, particularly in systems with rapid dynamics.
Sam Groves
Well different microcontrollers act differently on a system. A pure P microcontroller reduces the error and increases the final value , a pure I microcontroller nullifies the error and increases the final value and a pure D microcontroller increases the error and keeps the final value the same.
However when combining pure microcontrollers the net result will be somewhere in between right?
Since generally a microcontroller in the s domain can be written down as:K0+K1/s+K2s the net result depends on the constants K0,K1 and K2.Given K0,K1,K2 can we evaluate how the PID would act out?Is it like the RGB color or is it more complicated(K0 has greater weight than K1 or K2)?
No
Yes, it's more complicated. I don't think there's a good answer without knowing the nature of the system being controlled. Feedback compensation is tailored for each system to optimize performance based on desired behavior.
BTW, there's nothing special about PID. As a controls guy, I find it kind of annoying that that is what is always taught. You could have two integrator terms, no proportional term, etc. In fact my general advice is to just not use the derivative term unless you both need it and have a really good understanding of stability of feedback systems. It usually causes more problems than it solves.
Sorry, I don't know of a simple reference to explain this. You can search for "feedback compensation" to dig deeper; there's lots of good stuff on the web.
Likes nsaspook and Dullard
@Dave:
I don't disagree with anything that you said. I think that the emphasis on 'PID' is a result of the fact that for most standard industrial control hardware (PLCs, etc.), 'canned' PID is what is available. Many of the people implementing controls in an industrial setting have little/no understanding of the (mathematical) theory behind the 'knobs' that they're turning when they 'tune' a system. There are some surprisingly good empiricists running around. They lack the classical training that EEs get, but their approach accounts for the practical limitations of feedback (accuracy, latency, etc.) that some EEs never seem to 'get'. Obviously, a trained EE (with actual experience) is ideal.
I agree that 'D' is much less commonly required. Where 'D' is rquired, you absolutely need to know what you're doing - It's not useful in a temperature control for an oven with a 12-Hour time constant. For servo-valves modulating the application of aggregate to multi-colored roof shingles zooming by at several FPS, it's absolutely required. 'D' can always (at least theoretically) 'improve' the response - knowing when it's worth the trouble is the trick.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
