Can a Function in Polar Coordinates Fail in Cartesian Coordinates?
A function in polar coordinates can fail to be a function in Cartesian coordinates due to the nature of the representation. For instance, the polar function r(θ) = 1 + sin(θ) corresponds to a single value of r for each θ, but its Cartesian counterpart does not pass the vertical line test, indicating it is not a function y(x). The discussion highlights that the concept of functionality is dependent on the coordinate system used. While polar coordinates can define a function, Cartesian coordinates may not maintain that definition. Ultimately, the representation of a function can change its status as a function based on the coordinate system employed.
Undoubtedly0
Hi all. What does it mean that a function in polar coordinates may not be a function in Cartesian coordinates?
For example, r(\theta) = 1 + \sin\theta is a function because each \theta corresponds to a single value of r. However, in Cartesian coordinates, the graph of this function most clearly fails the vertical line test.
Therefore, functionality depends on the coordinate system?
It depends on the type of function you want.
  • If you want a function y(x), you cannot get the same graph as your equation gives.
  • You can find a function R->R2 with (x,y)(t), however, which gives one point (x,y) for each value of t, and has the same graph as your function.
  • You can find a function R2->R, f(x,y) where your graph corresponds to all points where f(x,y)=0.
I wouldn't call the property of being a function "functionality", but, yes, a set of ordered pairs representing certain information may be a function and when the same information is represented in a different way as a different set of ordered pairs, that other set of ordered pairs may fail to be a function.
  • · Replies 20 ·
