Is f a scalar multiple of g in Hom(V,F)?
  • Thread starter Thread starter Robert1986
    Functions
The discussion centers on the relationship between two homomorphisms, f and g, in the context of the vector space Hom(V,F). It establishes that if f(v)=0 implies g(v)=0, then g is a scalar multiple of f, denoted as g = λf, where λ is in the field F. The proof hinges on the equality of the kernels of f and g, leading to the conclusion that both functions are determined by their action on a common element in V. The discussion also clarifies that the assumption f ≠ 0 is crucial for the validity of the conclusion.
  • Understanding of vector spaces and linear transformations
  • Familiarity with the concept of kernels in linear algebra
  • Knowledge of homomorphism theorems
  • Basic proficiency in algebraic structures over fields
  • Study the properties of kernels in linear transformations
  • Learn about the isomorphism of quotient spaces in linear algebra
  • Explore the implications of linear dependence in vector spaces
  • Investigate the role of scalar multiplication in homomorphisms
Mathematicians, students of linear algebra, and anyone studying vector spaces and linear transformations will benefit from this discussion.
Robert1986
Let V be a vector space over the field F. Let Hom(V,F) be the set of all homomorphisms of V into F (this is a pretty standard definition, noting new here.) Now, let f and g be functions in Hom(V,F). If f(v)=0 forces g(v)=0 then g = \lamda f for some \lamda in F.
No relevant equations
So, since we are talking about mapping stuff to 0, it seems that we should look at the kernel of the transformations. We see that ker(f) is a subset (and hence sub-vector space) of ker(g). By homomorphism theorems, the quotient spaces formed by these kernels are both isomorphic to F, when F is being considered as a Vector Space. So V\ker(f) and V\ker(g) are both 1-D spaces and are isomorphic. So everything in each of the quotient spaces can be written as a multiple of a basis vector, v+ker(f) for V\ker(f) and u+ker(g) for v\ker(g) for some u,v in V. Ok, so since ker(f) in ker(g) it seems that everything in V\ker(f) can be written as a multiple of u+ker(g).
Other than that, I am kind of stuck on this. I need hints or ideas. I think perhaps I have built some sort of mental road block here. This problem is problem 4.4.11 from Topics In Algebra (Hernstein).
(note that you've been assuming that both f and g are nonzero)
Two things you don't really seem to have thought about:
And how does that relate to f and g?
g = \lamda f
That's the same thing as finding a homomorphism F --> F that makes a commutative triangle.
You have confused the order of inclusion in your solution. You have K(g)\subset K(f), where K(g) is the kernel, or nullspace, of the linear functional g (that's how elements in Hom (V,F) are called in the daily life).
Now, notice that the statement is wrong if f is identically zero; so we must assume f\neq 0. In this case, both K(f),K(g) are of dimension dim(V)-1, therefore K(g)\subset K(f) implies K(g)=K(f). Therefore, both f and g are determined by their action on some common element v\in V; if f(v)=\alpha\neq 0,g(v)=\beta\neq 0,\;\text{then}\; g=\lambda f \text{ where }\lambda=\frac {\beta}{\alpha}.
Hmm. f(v) = 0 implies g(v)=0 , doesn't this mean that Ker(f) \subset Ker(g) since anything that f maps to 0 g also maps to 0? But then we don't know from the problem statement alone that g(v)=0 implies f(v) = 0. Second, I don't think the problem is incorrect inf f is identically 0. All the problem states is that f(v) = 0 implies g(v) = 0 so if f is identically 0, then so is g.
I'm confused about what the rest of what you say, though. I see that the kernels are equal, but I don't get how it follows that g is a multiple of f.
Thanks,
Robert
You are right, I confused the order of inclusion and this also led me to think there is a problem with f=0. Anyway, here is a more rigor version of my proof:
if g is not identically zero, then both kernels are of the same dimension and therefore they are the same space. So, the kernel K=K(g)=K(f) is of dimension n-1. The functions f, g are determined by their values on the one-dimensional quotient space V/K, spanned by, say, v+K for some v in V. Now consider the values of f and g on this generator v (\alpha,\beta, like in my previous post) and deduce the linear dependence as I did earlier.
If g=0, then the statement holds for /lambda=0.
  • · Replies 41 ·
  • · Replies 26 ·
