How to Use Harmonic Analysis to Determine g(x,y) in Different Cases?
The discussion revolves around using harmonic analysis to determine the complex amplitudes g(x,y) of a monochromatic wave at different planes, given the amplitudes f(x,y) at z=0. The participants emphasize that the Fraunhofer approximation is not applicable due to the infinite extent of the input fields in both x and y directions. Instead, they suggest starting with the Helmholtz equation and applying the Fourier transform to obtain a function in the k-space. The angular spectrum method is recommended as the correct approach for solving the problem. Participants also request specific solutions for the cases presented, indicating a need for further clarification and examples.
Amirjahi
The complex amplitudes of a monochromatic wave of wavelength λ in the z=0 and z=d planes are f(x,y) and g(x,y), resprctively. Assume d=104λ, use harmonic analysis to determine g(x,y) in the following cases:
(a) f(x,y) = exp{(-jπ/λ)(x+y)}
(b) f(x,y) = cos(πx/2λ)
(c) f(x,y)=cos2(πy/2λ)
can anyone help me to solve this problem?
thank you
The other two sections of the template you have deleted are compulsory before you can hope to receive help. What equations in harmonic analysis, and additionally about the propagation of light, do you already know?
Fourier Transform Equations:
F(νxy)=∫−∞f(x,y)exp(−i2π(νxx+νyy))dxdy
Transfer Function of Free Space (Fraunhofer Approximation):
g(x,y)=h0exp(iπ(x2+y2)/λd)F(x/λd,y/λd)
3. The Attempt at a Solution
f(x,y)=1
F(νxy)=∫−∞exp(−i2π(νxx+νyy)dxdy=δ(νx−0)δ(νy−0)
g(x,y)=∫−∞F(νxy)H(νxy)exp(+i2π(νxx+νyy))dνxdνy
g(x,y)=h0exp(iπ(x2+y2)/λd)δ(x/λd)δ(y/λd)
Good start. Unfortunately, the objects (the fields in the input plane) are defined for all spaces, i.e. both ##x## and ##y## run from ##-\infty## to ##\infty##. In this case, the condition necessary for Fraunhofer approximation cannot be satisfied. Instead start with the Helmholtz equation in free space
\nabla^2 E(x,y,z) + k^2 E(x,y,z) = 0
with ##k = 2\pi/\lambda##. Now apply Fourier transform on ##E(x,y,z)## to ##x## and ##y## only, so that in the end you will obtain a function ##\tilde{E}(k_x,k_y,z)##. Hint: use the rule ##\textrm{FT}[df(x)/dx] = ik_x\textrm{FT}[f(x)]##.
blue_leaf77 said:
Good start. Unfortunately, the objects (the fields in the input plane) are defined for all spaces, i.e. both ##x## and ##y## run from ##-\infty## to ##\infty##. In this case, the condition necessary for Fraunhofer approximation cannot be satisfied. Start with the Helmholtz equation in free space
yes i know that, but i want a solution of one of the cases above for better understand
Do you mean one of the (a), (b), and (c)? All of ##f(x,y)##'s given in each case extends from minus infinity to plus infinity in both ##x## and ##y## directions, Fraunhofer approximation is not applicable here as it requires that ##a^2/(z\lambda) << 0.1## with ##a## the size of the input field. For instance, look at your previous work, in the input plane you have plane wave ##f(x,y) = 1##, but at ##z=d## you got a point as your calculation resulted in an expression proportional a delta function. Does it look make sense to you?
The right way to solve it is by the use of angular spectrum method. In case you are not familiar with it, start with the suggestion I pointed out in post #4. I just want to stress again, that Fraunhofer approximation will not work here.
ok thank you for your help, I will try to solve it if possible
hi
can i ask you the solution of FT[ f(x,y) = exp{(-jπ/λ)(x+y)}] ??
  • · Replies 61 ·
11K
  • · Replies 23 ·
  • · Replies 102 ·
11K
  • · Replies 33 ·
9K
  • · Replies 42 ·
11K
