FZERO or some method of computing the intercept points in MATLAB or Mathematica
The discussion focuses on solving the equation cosh(x)*cos(x) = x using MATLAB or Mathematica. Users encountered issues with the FindRoot function due to incorrect capitalization of function names and the use of parentheses instead of brackets. Correcting these mistakes allows for successful computation of intercept points, with examples provided for both simpler and more complex equations. A starting point significantly affects the solution found, demonstrating the importance of initial guesses in root-finding methods. Proper syntax and function usage are crucial for achieving accurate results in these computational tools.
ko_kidd
General problem--I don't know how to solve for the characteristic equation in MATLAB or Mathematica to find the solution of an equations such as
cosh(x)*cos(x) = x
(I know you can re-write this equation but it's just an example)
In Mathematica I tried:
In[2]:= FindRoot[cos[x]*cosh[x] == x, {x, 0}]
During evaluation of In[2]:= FindRoot::nlnum: The function value \
{0.+cos[0.] cosh[0.]} is not a list of numbers with dimensions {1} at \
{x} = {0.}. >>
Out[2]= FindRoot[cos[x] cosh[x] == x, {x, 0}]
In[4]:= Solve[cos[x]*cosh[x] == x, x]
During evaluation of In[4]:= InverseFunction::ifun: Inverse functions \
are being used. Values may be lost for multivalued inverses. >>
During evaluation of In[4]:= Solve::tdep: The equations appear to \
involve the variables to be solved for in an essentially \
non-algebraic way. >>
Out[4]= Solve[cos[x] cosh[x] == x, x]Is there some method of doing this in either program? I know I can get intersection points on my calculator but that defeats the purpose of using these programs.
You used this:
"FindRoot[cos[x]*cosh[x] == x, {x, 0}]"
SImply use capitals for the first letter of the functions like this:
"FindRoot[Cos[x]*Cosh[x] == x, {x, 0}]"
and you'll get x -> 0.893796
Built-in functions in Mathematica all begin with capitals.
Ah thanks for the reminder:
question though, what if I have something more complex like:
In[123]:= FindRoot[1 - Cos[x]*Cosh[x] == x*Sin (x)*Cosh (x), {x, 0}]
During evaluation of In[123]:= FindRoot::nlnum: The function value \
{0.+0. Cosh Sin} is not a list of numbers with dimensions {1} at {x} \
= {0.}. >>
Out[123]= FindRoot[1 - Cos[x] Cosh[x] == x Sin x Cosh x, {x, 0}]
Your problem is that in the part of the expression to the right of the ==, you have used round parentheses to surround the variable x. Change them to square brackets, and it should work. I get a solution of {x -> 0.}.
FindRoot[1 - Cos[x]*Cosh[x] == x*Sin [x]*Cosh [x], {x, 0}]
If I use a starting point of 3, like this:
FindRoot[1 - Cos[x]*Cosh[x] == x*Sin [x]*Cosh [x], {x, 3}]
I get a solution of 2.74914
