Galilean relativity and acceleration
The discussion revolves around the concepts of Galilean relativity and acceleration, particularly in the context of a thought experiment involving a closed box in outer space and the sudden appearance of a star. Participants explore the implications of acceleration and the equivalence principle in both classical and general relativity.
  • One participant suggests that in a closed environment like a train, uniform velocity cannot be detected, but acceleration can be, raising questions about the detectability of acceleration in a closed box in space when a star appears.
  • Another participant explains that in general relativity, a freely falling object is equivalent to one moving with constant velocity in flat space-time, and that gravity is not a force but a result of following curved paths in space-time.
  • A later reply emphasizes that while free fall feels like zero gravity, the presence of tidal forces from a nearby massive object could be felt, challenging the notion that acceleration is undetectable.
  • Some participants discuss the equivalence principle, noting that it holds in both Newtonian and general relativity, but with distinctions in how gravitational fields are treated.
  • One participant points out that the scenario of a star manifesting from nothing would violate energy conservation, suggesting an alternative scenario where the box approaches a star instead.
Participants express a range of views on the detectability of acceleration and the implications of the equivalence principle. There is no consensus on the specific conditions under which acceleration can be detected in the proposed thought experiment.
Some limitations include the assumptions about the nature of gravity and the hypothetical scenario of a star appearing from nothing, which raises questions about energy conservation and the definition of inertial frames.
AndyVo
Hello all. I'm a long time reader and a first time poster. I should start by saying that I am not a physicists or a physics student and am studying it merely out of curiosity so please forgive any ambiguous terms I may use that are not standard.
I came up with a sort of thought experiment to do with classical or special relativity. It is my understanding that to an observer in a closed environment such as a train there is no experiment that can betray uniform velocity. However acceleration can be detected. This makes intuitive sense when we think about how it feels to travel in an actual train.
But consider an observer in a closed box in outer space. Say that all of a sudden a star were to manifest itself from nothing some distance from this box. Suddenly there will be a force imparted on this box from the gravity of the star and it will be accelerated towards the star.
Is there anyway to detect this occurrence? That is, does the has the box's inertial frame of reference change? Intuitively it seems that this isn't detectable since everything inside the box is being accelerated at the same rate. (Doesn't free fall feel the same as 0 gravity?) Yet relativity states that acceleration is detectable.
I'm pretty certain my confusion stems from a fundamental misunderstanding of relativity but I'm not sure where I've gone wrong. Any help would be greatly appreciated.
In General Relativity, a freely falling object is equivalent to an object moving with a constant velocity in flat space-time. Both are considered inertial.
In your sealed box, you wouldn't be able to tell the difference between falling toward a star and moving with a constant velocity in flat space-time.
Relative to the star, the falling object is accelerating but it isn't proper acceleration. If you had an accelerometer while freely falling, it would read zero. In contrast, standing on the surface of the earth, you are rest relative to the ground but your instrument would measure an acceleration of 9.8m/s2- the latter scenario being equivalent to being on a ship in flat space-time firing its rockets and accelerating.
In GR, gravity isn't a force and objects aren't really attracted to each other; they are merely following curved paths (geodesics) through space-time. The curvature of space-time is caused by massive objects.
Wikipedia said:
In general relativity, a geodesic generalizes the notion of a "straight line" to curved space-time.
http://en.wikipedia.org/wiki/Geodesics_in_general_relativity
One caveat: If the object is large enough, or is falling toward a very massive object- a black hole for example, tidal forces become significant and the equivalence between the two scenarios break.
Tidal forces still exist for a small object falling toward the Earth or the sun, but are so small they can be ignored.
Here are a couple lectures that may help:
You're doing just fine here, as this is the basic insight that led Einstein to realize that free-fall in a gravitational field is no different than floating free in the absence of any gravity - they're both inertial frames. In general relativity, gravity isn't a force and it doesn't produce acceleration.
Search this forum and the net for "equivalence principle" for more details.
All right. Thanks for the quick and informative replies. It's starting to make a bit more sense. I'll look up the "equivalence principle" for more information :).
AndyVo said:
...Say that all of a sudden a star were to manifest itself from nothing some distance from this box. Suddenly there will be a force imparted on this box from the gravity of the star and it will be accelerated towards the star.
Is there anyway to detect this occurrence?...
You're proposing a gravitational tsunami. What the physicists wouldn't give for such an occurrence. They're building very delicate instruments to detect extremely small gravity waves. Of course you would be able to detect the gravity from the sudden creation of new mass. But don't worry, it's not going to happen.
Actually, you WOULD experience a force, a tidal force squeezing you together. Kind of like someone walking up behind you and pushing your shoulders together. Your free fall acceleration wouldn't be detected for the reasons outlined by the other commentators, but depending on the density and distance of this "presto" star, you would feel that tidal effect more or less. If that star were a black hole not so far away, that pushing on your shoulders would soon spaghettify you in a way that the force was certainly felt.
Haha yes that makes sense. So you would feel it but not in the sense that you feel you are accelerating. Interesting stuff, for me at least since it's all fairly new.
The equivalence principle also holds in Newtonian gravity. There, any time-dependent acceleration can be rewritten as a gravitational field. The big difference with GR is that in GR any coordinate transformation is equivalent to some gravitational field. So e.g., in Newtonian gravity an observer with a time-dependent rotation cannot pretend he/she is in a gravitational field, while in GR this would be possible (locally).
Strictly speaking, this can't happen: it would violate energy conservation. But you could imagine the closed box starting out far away from all other objects, but happening to have a trajectory that will take it close to a star. The effect would be basically the same, and everything the other posters have said would still apply.
In addition to the other responses, you will of course be able to detect that you are falling towards that star if you look out of the window; the box is not anymore approximately an inertial frame (in the usual sense of "Galilean" reference system). :smile:
Also a disambiguation: in post #3 "inertial frame" includes gravitation with inertia - thus a "free-fall-frame".
harrylin said:
In addition to the other responses, you will of course be able to detect that you are falling towards that star if you look out of the window; the box is not anymore approximately an inertial frame (in the usual sense of "Galilean" reference system)..
The one thing that makes the box not an inertial frame if you look far enough outside it is the tidal forces. In the absence of rotation of the box, the presence of tidal forces is both necessary and sufficient to show that you're not in an inertial frame. (With a sophisticated enough definition of tidal force you might be able to eliminate the remark about the box rotating, but if you just naively look for differences in acceleration on two ends of a rigid bar, you could conceiviable mislabel rotation of the box as a tidal force.)
"Looking out the window" just gives you a more sensitive way to measure the tidal force - a tidal force that has little effect over the cramped inside of the box might be much more obvious when integrated over a longer distance.
So I'd say that "looking out the window" doesn't really tell you all that much, it's mostly just a matter of even a small tidal force becoming noticeable if you integrate it over a long enough distance.
To present the formal argument, the presence of a true tidal force shows that there is geodesic deviation, and the geodesic deviation demonstrates that there is a non-zero curvature tensor, which means GR.
pervect said:
The one thing that makes the box not an inertial frame if you look far enough outside it is the tidal forces. [..] "Looking out the window" just gives you a more sensitive way to measure the tidal force [..]
I meant "looking" literal: surely optical effects can show it (aberration? Doppler? ..)
Why are we talking about a window in the box? The whole idea of the box is to prevent you from seeing or looking outside of it. It's not suppose to be a structure that you make measurements from. You're supposed to imagine that you are freely floating inside the box which is what will happen in reality.
  • · Replies 17 ·
  • · Replies 18 ·
  • · Replies 53 ·
  • · Replies 116 ·
10K
  • · Replies 0 ·
  • · Replies 24 ·
