What Are the Key Aspects of Galois Theory Illustrated by the Polynomial x^3 + 4?
  • Thread starter Thread starter PsychonautQQ
    Theory
The discussion centers on the Galois theory of the polynomial g(X) = x^3 + 4 over the rational numbers Q. The splitting field K of g(X) is determined to be Q(b, c), where b is the real cube root of 4 and c is a primitive sixth root of unity. The degree of the extension K:Q is established as 6, with the Galois group Gal(K:Q) identified as S_3, which contains 6 elements. The participants explore the structure of the Galois group and the corresponding subfields, ultimately concluding that the fixed fields of the subgroups correspond to specific combinations of b and c.
  • Understanding of Galois theory concepts, including splitting fields and Galois groups.
  • Familiarity with polynomial roots and their properties, specifically for cubic polynomials.
  • Knowledge of the structure of the symmetric group S_3 and its subgroups.
  • Basic understanding of field extensions and minimal polynomials.
  • Study the properties of Galois groups, specifically S_3, and their implications for field extensions.
  • Learn about the Galois correspondence and how it relates subfields to subgroups of the Galois group.
  • Explore the concept of solvability by radicals and its application to polynomial equations.
  • Investigate the relationship between roots of unity and field extensions in Galois theory.
Mathematicians, particularly those specializing in algebra and number theory, students studying Galois theory, and anyone interested in the properties of polynomial equations and their roots.
PsychonautQQ
Let K be the splitting field in C of the polynomial g(X) = x^3 + 4 over Q
a) determine the degree of the extension K:Q,
b) determine the structure of the galois group Gal(K:Q)
c) Using the Galois correspondence, determine all subfields of K
d) Let r be an element of K and let m(x) be the minimal polynomial of r over Q. is m solvable by radicals? explain
a) Q splits in Q(b,c) where b the 3rd real root of 4 and c is a primitive 6th root of unity. Then all 3 roots are in Q(b,c), and they take the form -b, cb and (c^5)b. The degree of the extension will be 6 because the minimal polynomial of b over Q has degree 3 and the minimal polynomial of c over Q(b) has degree 2.
b) The Galois group is ##D_3=S_3## and so there are 6 elements in it.
c) The subgroups of ##S_3## are <(12)> <(13)> <(23)> and <(123)>. Let's say 1=-b, 2=cb and 3=bc^5.
The fixed field of <(12)> will be Q(b(c^5)), whilst it swaps the other two roots -b and cb. I am a bit confused here because I think (cb - b) should be included in the fixed field because (12) would swap cb an b around and thus the term (cb - b) would stay the same. Is Q(bc^5,cb-b) the same as Q(bc^5) somehow?
Anyway, following my same logic, the fixed field of (13) will be Q(cb) or Q(cb, bc^5-b) or Q(bc^5-b). I hope the thing that is confusing me here makes sense.
Then (23) would fix cb + cb^5 and b so would the fixed field simply be Q(b,cb + bc^5)? My gut is telling me it's just Q(b) but I'm not sure why cb + bc^5 wouldn't be included, is this element in Q(b)? I mean c+c^5 would equal a real number I believe if you look at them as points on the unit circle, but I highly doubt this real number is linearly independent from the basis {1,b} over Q and thus cb+cb^5 would not be in Q(b).
And finally we have (123). I believe the fixed field of this would be Q(b+bc+bc^5).
d). I believe the answer is yes it would be a radical extension, since b^3 is an element of Q and so is c^6.
Thanks PF!
I assume you meant ##K=\mathbb{Q}(b,c)##. Anyway. Why did you choose ##c## to be a sixth root of unity? Shouldn't it be ##\sqrt{-3}## instead and you get directly the degree ##2## extension? But maybe they work both, I simply saw no reason for it and thus didn't really follow your constructions. I would have expected ##<(1,2,3)>=\{1,b,b^2\}## and ##<(1,2)>=<\sqrt{-3}>##.
An argument, why ##Gal(K,\mathbb{Q}) \ncong \mathbb{Z}_6## would be nice.
Regarding the solvability, you could simply calculate all roots and show (and prove) a basis of ##K## over ##\mathbb{Q}##, or otherwise argue with the corresponding property of ##S_3##.
Likes PsychonautQQ
Well, a 6th root of unity has a minimal polynomial of degree 2 and if we let c be the sixth root of unity then c^3 = -1 and (c^5)^3 = -1, and these are the only two powers of c that when raised to the third are equal to -1,. Furthermore, I believe that Q(b,c) is a splitting field of x^3+4, because the roots are -b, -bc, and -bc^5 and all of these roots are in Q(b,c), and also Q(b,c) is contained in Q(b,bc,bc^5) as (bc)^2 * (bc^5) = b^3 * c^7 = 3*c so c is an element of Q(b,bc,bc^5). I'm pretty sure what I wrote works, and I'm only saying all this so that you might find a flaw in my logic, because believe it or not I've been wrong before.
##Gal(K,Q) does not equal Z_6## because the minimal polynomial of b is x^3-4 and the minimal polynomial of c is x^2-x+1, where we will have one automorphism in the Galois group that takes b to the other roots of it's minimal polynomial. So there will exist an autmorphism such that b --> bc and an automorphism that takes c-->c^2, and these automorphisms are not commutative so the Galois group will not be ##Z_6##
______________________________
I'm not understanding your idea that b=the real cube root of 3 and c = (-3)^1/2. I understand that c and -c will both be roots of x^3+4 but how will we get the third root?
I simply calculated ##x^3+4=(x-b)(x- \frac{b}{2}(-1+\sqrt{-3}))(x- \frac{b}{2}(-1-\sqrt{-3}))## and ##\{1,b,b^2,\sqrt{-3},b\sqrt{-3},b^2\sqrt{-3}\}## is a nice basis (to be proven) for ##K \supseteq \mathbb{Q}## which almost already displays the group structure of ##S_3 = D_3 = \mathbb{Z}_3 \rtimes \mathbb{Z}_2##.
What has puzzled me with the sixth root of unity ##c## is, that ##c \notin K##, at least I couldn't immediately see it and you provided no proof. This way you get an isomorphic field ##K'## of ##K##, which doesn't really affect the solution, but I think ##K' \cong K## should be explained.
This has been the reason for me to chose ##\sqrt{-3}## instead.
Likes PsychonautQQ
Ahh cool so my solution does work also? If so, awesome. What will the fixed fields look like?
If you either prove that ##K## contains the sixth roots of unity (which I doubt is true), or establish an isomorphism ##K \rightarrow \mathbb{Q}(b,c)##. Simply assuming one of them is true, is a bit weak in my opinion.
It'll look like ##\mathbb{Q}##. What do you mean? Did you mean the intermediate fields? In my solution they will be ##\mathbb{Q}(b)## and ##\mathbb{Q}(\sqrt{-3})##. I have difficulties to clearly understand your solution, e.g. the connection between permutations to automorphisms should explicitly be defined in terms of basis elements. Also ##c^5## appears on the scene without any motivation. I know why, but shouldn't you explain it? And why are ##\{-b,cb,c^5b\}## all the roots? I think you leave a bit too much to the reader. (Or maybe I'm not that smart.)
Likes PsychonautQQ
well the polynomial has 3 roots and {-b,bc,bc^5} are all roots, so therefore this set must contain ALL the roots. (-b)^3 = -4, (bc)^3 = 4*-1 = -4, (bc^5)^3 = 4*c^15=4*(c^12)*c^3=4*1*-1=-4. Therefore Q(b,c) contains all the roots. However, to be a splitting field you have to be the smallest field to contain all the roots, which my field is not, because your field is contained in mine but mine is not contained in yours.
Nope. ##K = \mathbb{Q}(b,c)## - no isomorphisms or alike needed.
##c=\exp(2\pi i \cdot \frac{1}{6}) = \cos (\frac{\pi}{3}) + i\cdot \sin (\frac{\pi}{3}) = \frac{1}{2}(1+i\cdot \sqrt{3})## and similar for ##c^5## which shows ##\mathbb{Q}(b,c)=\mathbb{Q}(b,\sqrt{-3})=K##. (I only needed this line to see we're talking about the same numbers.)
Likes PsychonautQQ
So what you're saying is we're both genius's? Lol.
But actually, can you help me find the intermediate subfields using Galois subgroups and the Galois correspondence?
The Galois group is ##S_3## the subgroups are generated by (12), (13), (23), and (123). Let's consider 1 to be the real root, 2 to be bc and 3 to be bc^5.
That means that (23) is complex conjugation, so the fixed field of (23) is Q(b), because b is the only real root and the other 2 roots are flipped by complex conjugation. That being said, the element bc+bc^5 will also be fixed, because they will both go to each other, so is the fixed field of (23) actually Q(b,bc+bc^5)?
I am a bit confused here, because I feel like the fixed field should be just Q(b). I guess (bc+bc^5)=b(c+c^5) where c+c^5 is a real number because their imaginary parts cancel out (imagine where they lie on the unit circle to see this). But still, I doubt that c+c^5 is Q-linearly dependent from b.
. I believe the fixed field of (12) will be Q(b+bc), the fixed field of (13) will be Q(b+bc^2), and the fixed field of (123) will be Q(b+bc+bc^5).
But then again won't (12) also fix Q(bc^5)? So would the fixed field be Q(b+bc,bc^5)?
Do you see why I am confused? Thanks in advance.
It helps to work with explicit numbers in parallel.
Let us actually split ##x^3+4=(x+b)(x-bc)(x-bc^5)## with ##b=\sqrt[3]{4}\in \mathbb{R}\, , \, c=\frac{1}{2}(1+i\sqrt{3})\, , \,c^5=\frac{1}{2}(1-i\sqrt{3})##. Thus the identification with permutations should be ##1 \triangleq -b\, , \,2 \triangleq bc\, , \, 3 \triangleq bc^5##. (The minus sign has to be somewhere. I found it easier here, than to bother with it in any multiplications.)
Let us now consider ##bc+bc^5##. This is ##bc+bc^5=b(c+c^5)=b\frac{1}{2}(1+i\sqrt{3}+1-i\sqrt{3})=b \frac{1}{2}\cdot 2=b##, so ##\mathbb{Q}(b,bc+bc^5)=\mathbb{Q}(b)##. I haven't calculated the whole multiplication table in ##\mathbb{Q}(b,c)## which would certainly help, since, e.g. ##(1,3,2)## is actually an automorphism ##\sigma : \mathbb{Q}(b,c) \longrightarrow \mathbb{Q}(b,c)## with ##\sigma(-b)=bc^5\, , \,\sigma(bc^5)=bc\, , \,\sigma(bc)=-b##.
Likes PsychonautQQ
Yes, all these automorphisms are permutations. Would the fixed field of (1,3,2) be Q(-b+bc+bc^5)?
##-b+bc+bc^5=b(-1+c+c^5)=b(-1+1)=0## and therefore ##\mathbb{Q}(-b+bc+bc^5)=\mathbb{Q}##.
On the other hand ##(1,3,2)## belongs to the automorphism ##\varphi : \mathbb{Q}(b,c) \longrightarrow \mathbb{Q}(b,c)## with
##\varphi(-b)=bc^5\, , \,\varphi(bc^5)=bc\, , \,\varphi(bc)=-b##. Let us calculate ##\varphi(c)##.
$$\varphi(c)=\varphi(b^{-1}bc)=(\varphi(b))^{-1}\varphi(bc)=-(bc^5)^{-1}(-b)=c^{-5}=1\cdot c^{-5}=c^6 \cdot c^{-5}=c$$
Here ##\varphi## is an automorphism of order three, and ##(1,3,2)^2=(1,2,3)## the other ##3-##cycle. I would expect one subfield of degree ##3## and three isomorphic subfileds of degree ##2##.
Likes PsychonautQQ
Do you know how to calculate these subfields explicitly? Or even what the final result would be? What elements do we have to adjoin to Q to get the intermediate field that corresponds to the fixed field of <(123)>=<(132)>?
The only explicit method which comes to my mind is the brute force way to do it:
Chose a basis to express an invariant element, apply the automorphisms and solve the equation.
However, this doesn't seem to be very pleasant. I would take the subfields I suspect to exist instead, and verify their invariance.
As to ##(1,2,3)##. Here we know that ##\varphi(c)=c## by the calculation above (post #12), so we are left with ##\mathbb{Q}(b,c) \supseteq \mathbb{Q}(c)## which is of degree ##3## and ##Gal(\mathbb{Q}(b,c),\mathbb{Q}(c)) = <\varphi> \cong \mathbb{Z}_3 = \{1,(1,2,3),(1,3,2)\}## as expected.
Likes PsychonautQQ
  • · Replies 28 ·
  • · Replies 19 ·
